Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
I want to burn a dvd from what I have recorded in my dish network. How do I set up the player so I can watch the tv through it?
    Novelist:
  • 185 Answers
The easiest way to connect this is to find the cable going from the receiver to the TV and disconnect it from the TV. Connect this cable to the back of the DVD player where it says "in" or "input".
Next take another cable and connect it from the DVD player output to the TV. You may need to cycle or change your input by pressing the input or source button on your TV, in order to get a picture.
Daniel Busa
DISH Network
Customer Service
Posted on Mar 29, 2011
How do i burn movies from dish network? How do i view dish network with the unit on?
Hi abracadab628my name is Mike Houston of DISH Network and after reading over your post andthere is a simple solution to your recording questions. You can connect you're Phillips/Magnavox DVD/VCR and run it through the DISH Network receiver and set thetimers up on your VCR/DVD player.
Mar 29, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have surroundsound. I have dish network with hd dvr. I have a sony bravia hd tv. I have a dvd player, and cd player. I have a magnavox dvd recorder. I want to record from my dvr to my dvd recorder. ...
To get the functionality you're looking for you'll need to to take the cable running from your DVR output and connect it to the input on your DVD recorder. Next you want to connect a cable from your DVD recorder output and connect it to your TV. If this is an HD set up you want to use HD Cables for all of the connections.
Daniel Busa
DISH Network Customer Service
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
When we watch a dvd movie our dish network symbol floats around in the background. I have contacted dish, said not their issue contact sylvania
Hello, this is Dan Busa with DISH Network Customer service, What I would check is the cable coming from the receiver to the tv make sure you only have one set. If you only have one set coming from the box, check if it goes into the DVD player. If it does, hook the receiver up separately and it should work okay.
Daniel Busa
Dec 24, 2010 | Sylvania ZV450SL8
Connect dvd/vcr to HD-tv via dish network
Hey my nameis Mike Houston of DISH Network and I see where you want to run the SanyoDVW-6000 DVD/VCR Player to the DISH Network receiver. You can run the SanyoDVD/VCR directly to the TV and pick the channel you want to record and it willrecord the channel showing.
Dec 07, 2010 | Sanyo DVW-6000 DVD Player/VCR
Connecting protron dvd to dish TV
I hope you have at least 2 sets of RCA jacks for (1) the Dish receiver and (2) the DVD player. Run 2 sets of R/W/Y cables to the TV. Done. Or use S-video for a better picture instead of yellow.
If you only have one composite input on TV (possible) then either buy a 2-way or more switch for the composite signal (R=right sound W=left Y=composite or S-video instead of composite) or you can instead pass the signal through the DVD recorder on the RCAs but the DVD will be on whenever anything is on. I assume you do not have a Dish 111 with only RF output but the same could be done for just the wimpy RF, just different switch. So there will be 3 RCA cables from Dish to a recorder and 3 then to the TV. Since you do not have a recorder, then go back to the switch or find another TV input.
Ten years, hum, you may not have had composite/S-video inputs and would have to use RF only--you did not say what TV was.
-Ken
Jul 19, 2009 | Protron PD-800 DVD Player
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Mar 29, 2009 | Audio Players & Recorders
Sound interuptions with Samsung S4253
My set started having sound issues recently. Every now and then, randomly, I get a split second, static sound. It sounds like an old record player when it skips. It happens on all channels HD and digital. Also happens when I'm watching a DVD. This leads me to think that it's not my cable box (Dish Network). I have a Bose 321 aux amp plugged in. I hear it through my aux speakers, as well as directly through the tv set. Not sure what to do. Is it possible my tv's amp is burning out? What could be causing this?
Mar 28, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Watch while recording
Make sure the DVD has RF lead and Scart lead connected in and also BOTH connected out to the TV. When you record from TV use channel numbers, when you record from cable use AV channel, (on DVD). When watching TV use TV channels 1 to 5, when watching Cable use AV channel, (on TV).
Feb 06, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Connecting my DVD Recorder to Dish Network so I can record
If it is hooked up right to record as the program is on. Then make sure the input is set correctly, the tv should show pic from ext-1 the e-55 should be on channel 3. This should solve ur problem.
Jan 04, 2008 | Panasonic DMR-E55 DVD Recorder
Changing Channels
Unfortunately, no. The tuner in your DVD recorder works differently than how your satellite receiver works. You *must* use the satellite receiver to select the active channel, and then send that channel to one of the inputs on your recorder. You can then record that channel. Unless your satellite receiver is has "dual tuners" in it, you are stuck watching the same channel that the DVD recorder is recording. If your goal is primarily time-shifting of shows (as opposed to archiving shows forever to DVD), you might consider getting a different satellite receiver with a built-in DVR (hard disk recorder). These allow you to mark shows in advance, have them recorded to the hard drive, and then you can watch them whenever you want, skipping all the commercials. You also get the ability to pause and rewind live TV.
Apr 14, 2007 | Panasonic DMR-E50 DVD Recorder
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
42 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
