Question about Maytag Dryers
I have a maytag performa electric dryer with no heat, checked fuses, replaced heat element and thermostat, any ideas
  • 61 Answers
Have you checked to make certain you have the proper voltage where the dryer is plugged in? 220v? A dryer will run on 110v but requires 220v to heat. Could be a problem with the breaker in the breaker box. If you are not familiar with electricity, I suggest you find someone knowledgeable ie professonial
Posted on Mar 26, 2011
My Maytag Performa dryer is not heating at all .What should i do? Everything else works it just doesnt heat.
Hi
Replace the thermal fuse, and if possible test the heating group (thermostats and element or gas heater). You can replace the fuse straight away, or you can first test it using a multimeter set on OHMS. If the multimeter reads Ohms infinity when you touch the fuse contacts with its probes, then the fuse is gone.
If the fuse is OK, then you can have a defective thermostat or heating element (electric models), with gas models you test coils, thermostats and ignitor (flame sensor rarely fails).
After fixing the problem clean lint from air ducts, if the thermal fuse or thermostat has blown it means that there had been overheating.
May 09, 2011 | Maytag Dryers
I have a maytag performa dryer wont heat up sometimes
Hello there:
If there is no heat or heat sometimes please try these solutions
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 14, 2010 | Maytag Performa PAV2200
Maytag Performa dryer blowing heating elements
Hi and welcome to FixYa. You should check the dryer vent ducting inside and outside the dryer for restrictions / clogs to include the vent flapper. Poor air flow through the dryer will cause hot spots. If the blower is slipping on the motor shaft this too can cause poor air flow.
When you change the heating element AGAIN... break out the crevice tool and de-lint everything you can access. Also pull out the lint filter and wash it with white vinegar and water then soap and water. Fabric softener sheets material builds up on lint filters. It looks clean but air will not pass through the lint filter.
I think once you get it all ceaned up including all of the ducting to and through the outside wall it will work normally with no problems. I do not think at this time that you have an electrical problem with the outlet supply.
There is one more thing to check and that is the high limit thermostat. It could be STUCK. It will most likely be labeled L180 or L190. That thermostat is suposed to open at either 180 deg or 190 Deg depending on which one is installed. If it does not open then you will keep cooking your elements. We test them with a match and an Ohm Meter. Match under the removed thermostat CLICK. Thermostat opens (no resistance)
Wish ya the best.
Thanks for using FixYa.
Kelly
If anything in the future crops up with this same issue.
Apr 10, 2010 | Maytag PYE2300AY Electric Dryer
Will not start
it is likely the Thermal Fuse, LA 1053 kit for Performa Electric Dryers. You have to open the case, remove the drum, Loose the back panel and remove the Heater element case. The Fusible Thermostat is on mounted on the side of the heating element case.
Feb 26, 2010 | Maytag Dryers
No heat (replaced heating element and another
It sounds like you replaced the heating element and the small thing you refer to was most likely the thermal fuse. If these are the components that you replaced, and if they are indeed good, the next thing to look at if the dryer is not heating up is the high limit thermostat. It is most likely faulty if the element and thermal fuse are good. Hope this helped and best wishes. Here is a picture of a thermal fuse and high limit thermostat to help you figure out what is what.
Jul 30, 2009 | Dryers
My Maytag Performa stopped running. Checked breaker. Any ideas?
Your fuse is probably blwn due to some sort of blockage or blower wheel mafuntion. The fuse is located to the right of the heating element on the rear bulkhead. You must pop the top to get to the part. i have a page on dryers fuses and hi limit and how do I access my dryer. please feel free to browse away.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 09, 2009 | Maytag PYE2300AY Electric Dryer
Dryer element won't get hot
for safety reasons it has its own fuse and that may be your issue (new fuse $5)
To be safe i'd also get new thermostat ($15)
Apr 02, 2009 | Maytag PYE2300AY Electric Dryer
Need ohm readings for Maytag Performa Model PYE 3200AYW
Go to this site for info on your dryer type, you may find what you need there...
http://www.applianceaid.com/ww-and-mc.html
Jan 14, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Performa Pye2000ayw won't turn on-tried taping wires
If your dyrer has a thermal fuse, it will be on the blower housing (front), not on the heat element. It will be either white plastic os a button about half the size of other thermos. The fuse on the heat element will shut down the haet only. Hope this helps!
Jan 04, 2009 | Maytag HYE3658AY Electric Dryer
Dryers Logo
101 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
