Question about Panasonic DMR-ES30VEBS
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the disc, and I cannot finalise. I am using the same discs as before (sony DVD-RW). Would it be a problem with the Discs, what would you recommend. Thanks B
  • Panasonic Master
  • 508 Answers
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Posted on Mar 26, 2011
Testimonial: "Thank you for your advice. Will give it a go. Regards "
  • Demonic-2011
    Demonic-2011 Mar 27, 2011
    DVD-RW has always been a problem disc format with the early series of Panasonic DVD recorders. Just change to DVD+R/DVD-R and try those - (do not use DVD-R DL (dual layer) discs; these will NOT work in this unit) DVD-R/+R should work fine.
    If those fail also, maybe it's time to consider replacing the recorder - but only as a last resort and/or it fails completely. This after all is a 2005 model, and even though it suggests DVD-RW/-R/+R/DVD-RAM recording on the front, the -RW recording option is often not reliable. Be careful when using DVD-R/+R discs - as you can only record once per disc.
    All it should cost you here is a pack of DVD-R/+R discs, and you can keep all the DVD-RW discs you used so far - put them aside or use them on your PC.
My Panasonic recorder DMR-ES30VEB switches itself off approximately 5 minutes after it is switched on. Your help would be appreciated.
the problem is with SMPS section. Problem will be the voltage regulator may be defective.
After geting heat the regulator stop working and not delever the required out put voltage.
May 10, 2011 | Televison & Video
Display reads slf check and u99 whichIthink is a fault code.The unit is apanasonic DMR-ES30VEB dvd recorder/vhs.Any ideas?
Hi
U99 is a fault code, from memory i believe it is a communication error between the dvd drive and its controller, either way the machine needs to be serviced.
regards
TechSupp12
Dec 12, 2010 | Panasonic DMRES30V DVD Recorder/VCR Combo
I have a Panasonic DVD Recorder DMR-ES30VEB could you please tell me if this will still be able to record if I buy a new Panasonic digital TV??
Yes, connect to AV2 and you can select the output for AV2 from the menu.
Most tv's send a selectable signal out through av2 but if you match to your Panasonic, you may find it will automatically set up with the dvd recorder(like Sony Smartlink)
You simply go into the menu, select the av2 output set up and pick what you want to record. I.E. dvt, av1 etc.
Sep 04, 2009 | Panasonic DMR-ES30 DVD Recorder/VCR
Sony slv 715ub no stereo sound on tape playback
Hi, i have a Panasonic dmr-es30veb DVD ram recorder/VCR and i cant record one channel while watching another, as you can tell i am not at all technically minded and if you can help i would be grateful many thanks Eileen.
May 13, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
DMR-E50 DVD recorder versus DMR-ES15 are these equivalent recorders
The DMR-ES15 is a later model (around 2006/07) than the DMR-E50 (2003/04), but essentially both should do the same job so technically - a good equivalent in terms of recording and same brand so yes. The connections on the rear (of the replacement recorder) should suit and work with your other devices just as the old one did.
According to some other online reviews, the DMR-E50 has had a few issues with recording, and finalizing certain discs.
I'd say go for it - accept the replacement - as long as it comes with some kind of guarantee, works fully and has all the accessories (including remote, instructions etc.) you should be good. Contact the store and seal the deal.
I hope you can get this in time for Christmas.
Dec 21, 2017 | Panasonic DMR-E50 DVD Recorder
Recording a TV program on a Panasonic DVD Player/Recorder
DMR ES 10 does not record on R + disc . change to R - disc and try
Oct 03, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DVD problems
sorry to say but both of these sound like loader problems.ie the optics are faulty,you have to replace the full assy called a loader assy when this happens.Panasonic are the only company who offer part exchange tru authorised dealers.ie send back the faulty one and they will give reduced price on new one,.As to other makes see a lot of sonys with optic problems as well so isint just a panasonic problem.You could also try using ordinary dvdrs instead of ram discs as the optic has to work harder when recording and playing ram disc due to information contained.Hope I helped!
May 15, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Televison & Video Logo
199 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
