Question about Myryad M Series MI 240 Amplifier
Myryad MA240 will not power up, The glass fuses are not broken
Myryad ma120 power amp,loud pop when switched off
Sounds like a Electrolytic capacitor has failed. Search backwards from the speaker connections inside the unit to the main PC board. Replace the first ones that you come accross that are linked with the speakers.
Dec 15, 2012 | Myryad Z Series Z160 Amplifier
INSIGNIA NS-30HTV TV will not power on after a/c power failure
It may just be a fuse that is blown. If you take the back cover off and follow the power cord you should be able to find the a.c line fuse, it will be a glass fuse with metal end caps.
A blown fuse will show a broken filament inside or blackened glass. You may also have d.c fuses inside , they will look the same sa the a.c fuse. Their values should be written on the circuit board near the fuses and always on one of the end cap.
something like250V/3A for 3 amps. Hope this will help. Good luck
Dec 02, 2009 | Insignia NS-30HTV 30" TV
Will not turn on
hello check the glass fuse inside the power adaptor
if not a glass fuse it will be a soldered in fuse called a wickman all the best
shaun
Aug 04, 2009 | Nintendo Wii Console
Power requirement
David, rest assured you can purchase a VOLTAGE CONVERTER and use it overseas to adapt to other voltages. I would recommend you pick one up at any electronic dealers or check online as to what is available, GOOGLE: Power Converters Be sure to obtain one close to the wattage your unit requires
Feb 22, 2009 | Myryad M Series MDP 500 7.1-Channel...
Myryad MI 120 Failure
This is a serious amp problem either relay has died doubtful,sounds like protection circuit is active due to a dc problem in board
Jan 05, 2009 | Myryad M Series MI 120 Amplifier
Myryad Cameo Integrated Amplifier
Both channels? It sounds like the source is causing the static.
Mar 02, 2018 | Myryad Z Series Z140 Amplifier
Myryad MA500 blown channel
Try the repair directory on this site
Nov 20, 2007 | Myryad M Series MA 500 Amplifier
Pre-amp locks up
Check the repair dirctory at the bottom of this site
May 26, 2007 | Myryad M Series MDP 500 7.1-Channel...
Myryad M Series MI 240 Amplifier Logo
69 people viewed this question
Top Myryad Audio Players & Recorders Experts
 Grubhead
Grubhead
Gary Dumers
Gary Dumers
Are you a Myryad Audio Player and Recorder Expert? Answer questions, earn points and help others
