Question about Microwave Ovens
I have a mixer tap in the kitchen sink. The hot water tap runs fine but I am not getting any cold water. I also have a bath downstairs and the cold water tap there is fine
  • 2,510 Answers
You will have to turn off your water mains and strip your mixer tap. It is possible that the seal (if it is an older tap with a rubber seal) has become stuck or the threaded part that turns it has gone faulty. If it is a modern tap with ceramic seals, check the operation of the mechanism and see why the ceramic seal is not being opened.
Posted on Mar 26, 2011
  • tpanesar Mar 27, 2011
    Thanks for the advice - the tap is well over 12yrs old. Will give it a go and let you know
  • Hans Pearson
    Hans Pearson Mar 27, 2011
    There are so many different designs and systems of water faucets, it is difficult to give any positive instructions, but this site shows a very simple and older layout of faucets (we call them taps). Good luck. http://www.free-ed.net/sweethaven/bldgco...
How do I DEFROST CHICKEN TENDERS ?
Here's How It Works:
  1. Run hot tap water into a bowl.
  2. Check the temp with a thermometer. You're looking for 140 degrees.
  3. Submerge the frozen chicken.
  4. Stir the water every once in a while (this keeps pockets of cold water from forming).
  5. It should be thawed in 30 minutes or less.
How to thaw a frozen chicken the fast and easy way
How do DEFROST CHICKEN TENDERS Google Search
Oct 31, 2017 | Microwave Ovens
When I switch microwave on all the electric goes off downstairs. Have to switch it bak on from mains. Anyone got any ideas why??
You have too many things being pulled on one circuit, try plugging it in on a different curcuit. Most homes have at least two curcuits in their kitchen, so if your using a normal wall outlet, move it to one that is closer to your sink area.
Mar 21, 2013 | Microwave Ovens
Microwave worked this morning and now not.....made no noise just stopped heating.
HELLO.
The solution is to diagnose the magnetron as explained below.
* 1 Fill a mug with room temperature water from your kitchen sink.
* 2 Place the mug of water on the glass cooking plate inside the microwave.
* 3 Set the microwave on "High" for one minute and press "Start." You should hear the magnetron hum while it is working.
* 4 Remove the mug carefully from the oven by its handle. The magnetron is working properly if the water is hot or warm. The next step repair or a replacement of magnetron if the water is still cold.
Thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Magnitron does not go on unless i run the vent fan
HELLO.
The solution is to test the magnetron as explain below.
* 4 Remove the mug carefully from the oven by its handle. The magnetron is working properly if the water is hot or warm. Contact the manufacturer for repair or a replacement oven if the water is still cold.
Thanks
I have installed the muirfield model kitchen faucet. I attached the water hoses and I am not getting hot water when I turn to hot. I am only getting a trickle. bith my hot and cold water is turned on all...
You are going to have to take the line off again and check it for debris or any plastic guides that have slipped out of place. You may have an internal clogg caused by something getting into the hot side of the faucet. Check any screens on the faucet for pluggage.
May 06, 2011 | Microwave Ovens
We have a Blanco opera 6000 mixer tap and have lost the plastic inserts at the tap outlet that mixes the hot and cold. Can you advise where we can get spares?
I would contact them from this website http://www.blancoamerica.com/index.html?p=CONTACT_US and request a special order direct from the wear house. You could possibly get it for free depending how long you have owned it.
Mar 06, 2011 | Microwave Ovens
I am unable to use the Bellagio water cooler now as the cold water dispenser is leaking. There is a constant drip so I had to remove the water bottle, then drain all the water from the reservoir. I have...
Go to www.super-electric.com and send them a message about your problem. They have parts. I can't tell you if they will help you or not, I have just emailed them today as well. I have both sides of my 1 year old water cooler leaking, model W074DRF11BQD. (from Zellers) I have hardwood floors and I would rather throw this unit away than risk water damage. If anyone is reading this and thinking of purchasing one of these Bellagio water coolers, spend your money elsewhere - THEY LEAK!. My husband is very handy and has just spent 2 hours on it with NO success. The parts are defective - this unit is NOT full of complex working parts. One plastic part causes pressure on the valve and causes a leak(s). After light usage and nothing damaging it, 8 months old one side went and the other side has been leaking for a couple of days and we are just coming up to a year. If anyone else had this problem and fixed it, I would love to hear the solution.
Dec 26, 2010 | Microwave Ovens
Microwave Ovens Logo
146 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
