Question about Dell Inspiron 530 Desktop Computer
Comes up no opererating system.sees hard drive and cd rom.does not read vista disk in cd rom.know cd of vista good,do i just need to change out cd rom drive?
    Guru:
  • Dell Master
  • 1,705 Answers
I think your PC is trying to boot from a hard drive without an operating system.
You'll need to change the boot option in the bios from HDD to CD.
When the boot screen comes up, look at the bottom of the screen, it'll say something akin to
Select "DEL" for SETUP or F2 for boot options, you can use either, but remember if you choose to change the setup, it will be a permanent change until you reset it.
Hit the requisite button, read the screen to change "The first boot device" to CD. If you change just your boot option, your pc should then boot from the Disk.
If you decide to change the bios (setup) settings you'll need to save and exit. Unless you're very sure, just change the boot option for now.
Posted on Mar 26, 2011
I need to format the hard drive using vista
ok follow this steps now. 0. Configure your BIOS and select DVD/CD ROM Drive, SATA or IDE for the first booting of the system. 1. you should have CD/DVD ROM SATA or IDE. Any of it you can use for the operations, and it's should be attach on you system unit. 2. When you are done on step 1. You can now Enter the Vista DVD/CD Disk Installer inside the CD/DVD ROM SATA or IDE. 3 Restart your system unit to proceed to the operation. 4. Automatically the system will launch the Operating System Files and it will Record all your information inside your hard disk.
Apr 10, 2010 | Compaq Presario CQ60-220US PC Laptop
Trying to install XP when disk selection comes up it reads, "Unkown disk. There is not disk in this drive". NOt sure what that means.
your drive is not being read,
have you set BIOS to boot from CD ROM,
is your CD ROM working,
is your XP CD working
Do the following
1 go to BIOS and re-set to BOOT from CD ROM
2 use another copy of XP/Win98/Vista etc to verify if CR ROM is reading the CDs else...
if you doubt CD ROM drive has a problem....
3 use a USB external CD ROM, and to do that u need to re-set the BIOS to boot from USB CD ROM
Dec 07, 2009 | IO Magic Corporation GigaBank (I250HD35)...
System reboot
Depending on what bios it has it may not show the cd drive. All you can do is set it to auto or if it has the option to cd or atapi. Then set the boot order so that the cd is looked at before the hard drive and you should then boot off of the cd.
Oct 24, 2009 | Acer Aspire 3610 Notebook
When i turn on my laptop it says invalid system disk.replace the disk and then press any key
You probably are using Windows XP. With this error, you must re install your Windows XP operating system with your XP CD.
Oct 21, 2009 | Computers & Internet
Trying to run recovery disc on computer and cd rom isn't reading
I see this as one of 2 possible failures.
  1. Optical drive failing. Take out the Hard drive, see if the recovery disk, or another bootable disk will boot. If no change, replace the optical drive.
  2. Hard Drive failing. If the system will boot to a CD with the HDD out or if replacing the optical drive has no change, then the HDD is the next logical failure point.
Apr 02, 2009 | Compaq Computers & Internet
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
My laptop not working
It seems to be a problem with your hard drive. Or your operating system files have been corrupted. If you do not have any critical data on the computer, I would go for a reinstall of windows
Aug 13, 2008 | Compaq Presario 700 470024-192 Notebook
CD rom can't read CD XP
yes i think the cd rom is the problem ,use external cd drive for the re installation or you can use a flash disc
Jul 12, 2008 | Acer Aspire 4315 Notebook
Windows XP Unsuccessful on Start Up
no you just need to fix your bios problem, if you dont have the manual take the battery out of the motherboard that keeps power to the bios keep it out for a few minutes put it back in then turn it on it should go to bios automatically then just go to set best defaults for ststem hit y for yes then hit enter and it should take off fine if it dont then you need to take it to a pro who can reset it for you manually or reprogram it that would be cheapest for you without trashing it.
Dec 30, 2007 | Acer Aspire 3000 Notebook
Ntldr is missing
seems your MBR is damage. but you can repair it if only you can boot in windows cd and entering in the recovery console.
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.    Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.    When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.    If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.    When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.    At the command prompt, type this commands one at a time.
FIXMBR  C:
FIXBOOT  C:
COPY [CDDRIVE]:\I386\NTLDR  C:\
COPY [CDDRIVE]:\I386\NTDETECT.COM  C:\
BOOTCFG  /rebuild
6.    To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
no warranty...you use on your own risk :)
Oct 27, 2007 | Compaq Presario sr1111nx 2.53GHz Celeron...
Dell Inspiron 530 Desktop Computer   Logo
176 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
