Question about Hitachi 250GB Hitachi 2.5" SATA Hard Disk Drive (5400rpm, 8MB cache) Hard Drive
Is there a jumper setting to run my hitachi 250 gb sata laptop hdd as a slave ?
    Guru:
  • 1,705 Answers
There should be, look on the rear of the drive, close to the SATA and power connectors, you should see the jumper connections as well.
It varies from drive to drive, but the jumper setting could be engraved near the connector, look of SL for a slave setting.
If no, look on the label on the top of the drive, there should be the jumper settings listed there.
Some may be ambiguous, my last one offered the option of Master on / off. (Jumper in position 1 for on, no jumper for off) The off in this case was of course slave.
The result being, no jumpers - Slave.
Posted on Mar 26, 2011
Slave hard drive jumper settings
This is a sata interface on ST3250824AS drive right ?
According to http://www.seagate.com/support/disc/manuals/sata/100390001c.pdf
there is no slave setting
section 3.2
Feb 23, 2016 | Seagate (ST3250824AS) 250 GB Hard Drive
Hitachi Hard drive DK23EB not readable -please help
Have you put the hdd from the laptop into slave mode, its on the back of the hdd, there might be a "jumper" that you need to reposition, failing that only insert the 1 hdd from the laptop and make it the only hdd, it should have an operating system on to run as normal. You can see the <jumper> on the right of this picture, you will need to connect both teminals (slave) with a little plastic jumper.
Apr 03, 2014 | Hitachi TravelStar DK23EB Series DK23EB-40...
Trying to make my seagate barracuda 7200.9 slave
1) Open your computer case
2) On the back of the drive where the connectors are, you have jumpers. These small plastic tabs change the function of your hard drive. All hard drives have a special setup procedure. The information about jumper settings is on the top of the hard drive.
3) Remove plastic tabs and put them according to "Slave" instructions.
4) Connect drive to middle connector of the cord.
5) Connect power supply cord.
6) Secure the drive in place and close computer case.
Also make sure that the main drive is not set as slave.
Apr 10, 2011 | Seagate Barracuda 7200.9 80 GB Hard Drive
Jumper setting for slave drive
there is no such master or slave setting when SATA is used.
it is mainly used to tell the motherboard which one is master or slave when connected with IDE cable (PATA).
you don't need to worry about it as you are using a SATA HD.
the boot disk priority can be set in the BIOS
press del or F2 after you press the power button on CPU. you will be put with the BIOS/CMOS setup. go to boot priority and set accordingly, there is also an option to set the default hard disk in case you have more than one HD.
Sep 04, 2010 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
I have a samsung 2.5" sata hdd that I want to make it from a master to slave. I need a pin jumper setting info.
You dont need jumper settings for sata hard drive, the sata ports on *********** board have the configuration, just connect the new hdd to the 2nd sata port.
Mar 24, 2010 | Samsung (MP0804H) 80 GB Hard Drive
I want to set this up as a slave drive in my Dell Inspiron. What are the jumper settings to do this
this is a SATA HDD, so to make it a Slave drive, it will need to be on the SATA-1 or later controller (The Boot Drive should be Sata-0)
Mar 19, 2010 | Western Digital Caviar SE WD2500JD 250 GB...
How to set master, slave settings in sata hdd
In first HDD put the jumper in first vertical pair of pins from power socket side, it will become master and second HDD put jumper in second vertical pair of pins from power socket side it will become slave.
Regards
Ashly
Feb 02, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
May 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Hitachi 250GB Hitachi 2.5" SATA Hard Disk Drive (5400rpm, 8MB cache) Hard Drive Logo
720 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
