Question about Astra Coffee Makers & Espresso Machines
My ex changed some fuses in my astra the other day, everything seemed fine until i was coming home from work and smoke was coming out of the dashboard. i got home and now my central locking does not work, i have changed the fuse and also noticed he used some higher fuses where he shouldn't of and sync my key in the ignition but still nothing do i need new wiring?
    President:
  • 1,489 Answers
Most likely the higher amp fuses allowed a shorted circuit to contune to function which overheated some wiring and burned the insulation causing the smoke. Yes, you probably will need to replace some wiring. But, first the shorted / overloaded circuit needs to be identified and repaired.
Charlie
Posted on Mar 26, 2011
Electrical probrems
replace the relay. may be stuck.
May 26, 2013 | 1999 Dodge Durango
1996 tahoe won't start
try fittung a larger capacity battery this will help when you are parked for extended periods of time, but it does sound as if you have something draining the battery, try getting the alternater checked
Nov 15, 2008 | 1996 Chevrolet Tahoe
I just bought a 1993 honda accord EX. I replaced all the brake pads and LR caliper and bleed the brakes. The other day coming home in trakkic with my AC on, my brakes went all the way to the floor. I...
Do you still have the problem ? If so, try disabling the ABS completely (electrically) by disconnecting the 50 amp breaker and remove the ABS controller. You should have brake power restored and be careful as the brakes will lock now if you apply too much foot pedal pressure. I hope this helps.
Jul 27, 2008 | 1992 Honda Accord
Vauxhall astra radio keeps switching on and off on its own
I had this problem for the last 2 weeks, didn't think much of it, but recently the car radio just turned on and off by itself, it decided to do so whilst the car was switched off and it drained my battery. After doing some tests with the Amp meter and removing the fuses for the radio and infotainment system the amps going through the batter went from about 0.7 to 0.001 (far more accpetable) - so the radio was draining the battery and randomly turning itself on/changing stations and the internal display system had stopped working.
after putting the fuses back in and re-testing the radio worked fine (almost like it had a full reset - no random turning on and off OR changing of radio stations)
the fuse box for my astra was next to the battery under the bonnet (see your car manual - I had lost mine so googled for it)
http://pdfcast.org/pdf/2006-vauxhall-astra-owners-manual-operation-safety-and-maintenance
PAGE (267 or 265)
but it seems yanking the fuses for the radio (FUSE number 35 and 36) seemed to fix it (been a few days and no flat battery) -
It maybe an intermitent fault, in which case i'll have it looked into, but as garages charge an arm and a leg i'd give this solution a go and if your battery is good all you need to do is remove the fuses and put them back after say a minute or so)
Jun 24, 2008 | Audio Players & Recorders
Astra home electric grinder
Turn adjustment ring towards fine, until it cannot move, then back towards coarse about 5 numbers, that should give you a good start on the grind.
May 17, 2008 | Astra Home Grinder Electric
Clarion dxz545mp doesn't power, does not work.
Check the fuses in the fuse block under the hood. Your clock fuse and radio constant power fuse are combined in this vehicle.
Jun 11, 2007 | Clarion DXZ545MP CD Player
Coffee Makers & Espresso Machines Logo
102 people viewed this question
Top Astra Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ross Keen
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Astra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
