Question about LG Refrigerators
LG express cool no frost GR 332 SF fridge.freezer rock hard ,food compartment warm. motor seems to be always on.ambient temp 20C.could faulty thermostat somewhere be the problem?
Just defrost the fridge. Once defrosted, the food compartment below the freezer should cool.
Posted on Feb 10, 2013
I had the same problem - repairman was just here - it was the defrost motor was burnt - the freezer had frost buildup behind the panel, which was not allowing the cool air to circulate to the fridge compartment
Posted on Aug 16, 2011
I'm getting frost and ice build up on the bottom and back of the fridge compartment on my LG French door fridge.
To me This is on all Makes and models build up of frost means warmer humid air is entering into colder air this will cause a frost build up from entrance of warm air coming in so your looking at your air flow in all compartments of your ref,freezer so on.
blocked air will give false readings to sensors when compartment is asking for lower temp colder temp will be noticed.
bad or obstructed door seals door not closing properly
Follow your frost line it will point the way.
Jul 21, 2015 | LG Refrigerators
LG GR-S512GCA NOT COOLING
check and see if compressor is kicking on and off after a few sec if it is you might try a hard start on the compressor its a little switch that goes on the compressor where the wires go cost around thirty dollars be worth a try before going out and buying a new fridge
Jan 27, 2014 | Refrigerators
Rm4400 freezer working fridge not
move temp sensor that's mounted in coils down or let hang if same replace sensor
Jan 19, 2014 | Dometic Refrigerators
This unit is used in a garage as a 2nd unit. It
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
Freezer works great, fridge not cold. about 60 degrees in fridge. had repair man look at the fridge, said the mother board, was bad. panel inside freezer iced uped. fridge seem to get better for about 2...
And you are posting because,.......????? You are looking for a second opinion? Don't like the repair estimate?
1. Your freezer is not working great. If it is frosting up, frozen packages will soon beging to soften also.
2. All of the cooling takes place in the freezer compartment. A fan blows air over the coils in the freezer, and directs some of it into the fresh foods side to cool it. When the coils become blocked with frost, the air can no longer flow into the fresh foods compartment. Result is warming of FF area. You may also see freezing in the bottom FF bin, water dispenser not working, FRZ section warm, etc.
3. Manually defrosting the coils will temporarilly solve your problem, but it will reappear in a few days to a week or so. (depending on door openings, ambient temp, etc)
4. The motherboard controls the defrost interval and (although not the most common) certainly can be a cause of defrost failure. If a qualified servicer diagnosed it as such, it most likely is just that.
Sep 16, 2009 | GE GSH25JFR Side by Side Refrigerator
The fridge and freezer stopped cooling. we defrosted it. There was frost in the freezer. Before that the ice on the door had stopped and now it works too.
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me,the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signaled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week).Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments which opens when the fresh food side needs cooling. If no air is moving in the freezer compartment, temps in the fresh food compartment climb.
I replaced the temp sensor in the fresh food side and solved the problem for a while.
I bought a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
About six months later I had the coil icing problem again. This time the fresh food side seemed cool enough (according to the thermometer as well as the fact that the flapper door would close, indicating that the computer knew to not try to additionally cool the fresh food side).
The thermometer indicated that the temp in the freezer compartment was cold enough, but the system computer continued to run the compressor. So I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
LG GR727RB Top Freezer ok but bottom fridge is not cool
Hi softwaredude with an LG GR-727R refrig. The occasional build up of water on the bottom of the fresh foods sections tells me that the refrig is going through it's defrost cycle, but that the defrost drain is plugged. If you take the back off the refrig. you will see a plastic tube about 1/2 inch diameter with a few ribs on it going from the top of the compressor compartment to the bottom, which is a defrost water holding / evaporating pan. Look to see if that tube is plugged. If not, it is plugged further up, most likely where the defrost water drains off the evaporator (that the coils behind the freezer wall that do all the cooling). Take that back panel off and use a hair dryer to melt all the frost off. The frost is blocking air flow from the freezer section to the fresh foods section, thus poor or no cooling in the FF section. You should be able to spot where the defrost water is suppose to drain. If the water is not draining out, use a turkey baster with hot water to flush out the drain.
Dec 04, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
May 22, 2008 | Frigidaire Refrigerators
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
1,431 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
