Question about Kohler Electrical Supplies
1982 kohler in rv put in new brushs only putting out 96 volt
    Sergeant:
  • 259 Answers
Try raising the engine rpm slightly. there should be a adjustment on the piece that hooks to a spring which is connected to the governor arm.
Posted on Mar 26, 2011
My generac rv generator runs bu no voltage output.
Try putting 12 volts across the commutator at the brushes. Ust a low current battery nor a car storage battery.
Good luck,
Marty
Jul 16, 2014 | Generac 5754 4.8 kW 120/240 Volt PrimePact...
1982 Honda GL 1100 Gold Wing try to start and solenoid clicks
Hi, Anonymous you turn on the ignition switch press the starter button and all you get is the dreaded "CLICK" now before testing any electrical component in the Starter System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries and the usual suspects are:
1. Battery terminals have loose or corroded connections.
2. Battery cables faulty due corroded or broken internal wiring at the cable connector especially the "NEGATIVE" cable which needs to be checked at "BOTH" ends.
3. Battery voltage, must be 12.5 volts or better, voltage from the battery to the main circuit breaker to the ignition switch to the security/ignition fuse to the TSM/TSSM module to the engine stop/run switch to the starter button to the starter relay to the green wire that connects to the starter solenoid can not drop more than 1/2 volt of battery voltage.
4. Disconnect spark plug cables, with a voltmeter connected to the battery, the ignition switch in the on position, the kill switch in the run position, the starter button depressed, starter engagement should not bring voltage below 9.6 volts DC. If the voltage is below 9.6 the battery is faulty and must be replaced. I "HIGHLY" recommend a maintenance free AGM battery typically they have more amperage for cranking.
5. Faulty starter relay, check continuity.
6. Faulty starter solenoid, check contact plate and shoes for excessive electrical erosion/etching, refurbish as necessary or invert contact plate and use the virgin backside. Check contact shoes for being loose. Replace solenoid if the negative function is still a final outcome.
7. Faulty starter, bench test starter with a 12-volt battery if negative function check, decontaminate and undercut armature commutator segments as necessary, check segments with an ohmmeter probe each one and the segment next to it for shorts. Have the armature tested with a growler and field coils, and brush plate with an ohm-meter for opens, shorts or grounds. Replace brushes if less than .438" It is generally cheaper to overhaul/refurbish a starter motor than buying a new one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
GL1100 starter solenoid only clicks when push the start button
What to do When Your Motorcycle Won Start
Honda GoldWing GL1100 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda GL1100 1982 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 02, 2017 | 1982 Honda GL 1100 Gold Wing
I have a Kohler Confidant 5, model 5ckm21 generator in my RV, serial # 326827, spec# 101228. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depresse
no 14vac coming from generator to control board.--cause can be regulator board on end of generator---dirty brushes or worn out brushes==b1 and b2 winding open that outputs the 14vac--my problem was blown regulator board
Dec 05, 2012 | Kohler Electrical Supplies
1982 flh hard to start new starter,battery,everything new cranks real hard
Check your conections earth and positive wire,or starter motor brushes need replase.
Sep 29, 2012 | Harley Davidson FLHTCUI Electra Glide...
Kohler Confidant 4 puts out to much voltage
Are you running the gen and plugging in the RV at the same time? I assume it is wired right and you have a transfer switch? Are you saying the voltage is fine when the RV isn't plugged in?
Apr 15, 2012 | Kohler Electrical Supplies
Kohler whirlpool control - missing wiring diagram - 1982
those parts made by unimax as you have found out are no longer made. solution is to put a new pump and control in.
Mar 22, 2010 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
I have a kohler rv generator that will start .
When this happens, this usually means that your genset is not creating voltage. First thing I would do is disconnect your remote start wire from the genset, this will eliminate the start switch inside the RV. For a shorted remote start switch can cause you genset to shutdown. Second, place a volt meter at a spot where you will be able to read genset voltage. If no voltage is available and your voltage regulator is new, then the problem is with either the rotor or stator. The rotor is the easiest check. You need to reach the brushes. Take a resistance reading, which should be around 20 ohms. Clean the rings and make sure there is enough length on the brushes, at least over 1/2". Next, flash the fields using a 12Vdc battery. Use rubber gloves when doing this. Place the positive side to the ring closest to the bearing and negative goes to the back ring. This is done while genset is running so be careful with rotating parts. Have a volt meter on the output wires. Once you flash the fields the voltage should increase to over 50Vac. If it does then your stator is bad since you installed a new voltage regulator. If the voltage does not increase when flashing, then the rotor is bad.
Apr 10, 2009 | Electrical Supplies
Alternator not charging
Hi
If you have a volt meter, set it to volts and hold the negative probe to the alternator body and the positive to the battery positive. If you don't get battery voltage then the alternator isn't grounded and the probable cause is the main engine ground cable either breaking or coming loose.
Very best regards
Geordie
Jun 10, 2008 | 1982 Ford F 150
Electrical Supplies Logo
106 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
Craig Butler
Craig Butler
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
