Question about ASUS M2V Motherboard
I cant use both speaker out in front and rear at the same time. i dont know why?
  • ASUS Master
  • 27,725 Answers
Click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 26, 2011
HOW DO THE WIRE GO ON A2003 SIVERADO
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Red
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Red/Black
Car Stereo Amp Trigger Wire: Pink (also known as the remote wire)
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Here is the installation manual for your particular deck. Click Here. The first thing you should focus is getting the unit to power on. Follow the diagrams and you should be fine. Once you get your deck to power on then you can move on to the speakers. I tried to provide as much info as I can. Let me know if you need anymore help
Jan 28, 2012 | Eclipse AVN5435 Car DVD Player
Wiring after market spekers need to know if a or b is positive or negitive
dont know about a or b but wiring should be color coded. these should be the colors and description for 02 silverado
Dec 31, 2011 | 2002 Chevrolet Silverado 1500
STERIO WINRING DIAGRAMS
dont know about a or b but here is diagram by color code
Dec 31, 2011 | 2002 Chevrolet Silverado 2500HD
Wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Jun 25, 2009 | Clarion DXZ945MP CD Player
I dont know which wires are which in the dash of a 1987 dodge dakota
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/White
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Green
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black/Yellow
Left Rear Speaker Negative Wire (-): Gray
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Orange
May 04, 2009 | Car Audio & Video
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
I dont know what size speakers are in my car
Front: 6.5" x 3" Deep
Rear: 6.5" x 3.25" Deep
1" Separate Tweeter (if equipped)
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Apr 01, 2009 | Audio Pro Car Audio & Video
1996 eagle vision radio wiring
1996 Eagle Vision Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Black/Yellow
Car Radio Ground Wire: Black/Light Blue
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Pink
Car Stereo Antenna Trigger Wire: Orange/Red
Car Audio Front Speakers Size: 3 1/2′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Feb 23, 2009 | 1996 Eagle Talon
I bought the LG LHT854 and i dont know how to connectthe speakers because i dont know which ones are the front speakers and rear speakers, all 4 speakers are the same and i dont know how wich is wich..
All four of the small speakers are identical, the original speaker wires are color coded. the very ends are all black and red, corresponding to the black and red connections on the back of the receiver and on the speaker, and there is another color band lower on the wire, which corresponds to the color on the receiver speaker connectors that details front right, front left, rear right, rear left, center, subwoofer.
If you are using standard speaker wire, it has two colors. Pick one for the red, and one for the black.
Just be consistent and connect all speakers the same at both ends (Copper color to plus-red / silver color to minus-black)
Dec 24, 2008 | LG LHT854 Theater System
1996 chevy 1500
with the ignition in the "off" position get a test light and touch one wire at a time while cycling the ignition switch to the "on" position, When you see that the test light goes off when the ignition switch is in the off position then you found the hot wire, make sure you dont hook it up to the "alway hot " wire or you might drain the battery hope this helps.
Oct 18, 2008 | 1996 Chevrolet Express
ASUS M2V Motherboard Logo
47 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
