Question about Sony Audio Players & Recorders
How to open the speaker system box of sony ss-gnv111d to change the wire damaged by a rat
michigan man
  • 3533 Answers
SOURCE: rats chewed wiring in engine compartment
try this place they sell only GM parts Schram auto and truck parts 1-800-292-1032 or online at www.schramauto.com
Posted on Apr 04, 2009
hattonhall
  • 349 Answers
SOURCE: Wiring was damaged by the rat. could not identify coded wir
google the manufacturer and ask for Maintenance Manual
Posted on Oct 25, 2009
  • 8 Answers
SOURCE: 1999 camaro ss The car will turn over but will
replace the igmition coil
Posted on Nov 23, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a Sony HT-SL55
The curse of some all-in-one HTIB's is proprietary color-coded speaker connectors where cheap plain old lamp cord or speaker wire would do.
$55
http://cgi.ebay.com/SONY-DVD-Home-Cinema-Speaker-Cables-FULL-SET-5-/260734977463?pt=LH_DefaultDomain_3&hash=item3cb50405b7
Posted on Mar 19, 2011
  • 159 Answers
SOURCE: will i be able to
Hi, As long as you like the way the speakers sound there is really no reason you cant use whatever speakers you want. To find out the approximate wattage of the stereo you are using look on the rear of the unit and you will find a tag that has " SPECIFICATIONS " on it. There you will see perhaps the a.m. and f.m. frequencies it's capable of receiving also there should be numbers saying something like" 100-240vac or 100-240v~ 50-60hz 1.2amp or 120watts.( if power is listed in amps only-1 amp's equivalent to about a hundred watts)Dividing the wattage by 3 will give you an approximate power out put. Example if your stereo draws 120 watts worth of 110 from the wall it will put out approximately 40 watts to each speaker. Changing from OEM speakers is all right as long as you don't try to hook up some 150 watt peak speaker to a stereo capable of just, say, 10 watts per channel. Doing this will eventually cause damage to the amplifier, not to mention causing about 30 percent total harmonic distortion-which take my word for you will know if you ever hear it! So long story short-use what you wish, just be careful not to overload the receiver-if the speakers are a bit to powerful for receiver you can lessen distortion by turning down the " BASS" as that takes the most power in a speaker. Thanks for choosing FixYa, I hope this helped-good luck, Prodzilla
Posted on Apr 16, 2011
Hello, I have a little giant #508158, pump is approx. 2 years old used about 4 times to drain a residential pool that is in-op @ the moment, however the pump has stopped working, the GFCI does "not" trip,...
To be precautious, if the damage to the wire is near to the appliance you might be lucky enough to savage it as it is hard to come by. Cut the wire 2 -3 inches away from the damage and hang to drain dry for 2 days or so if there is any sign of water ingress. leave the damaged wire in situ until you are ready to remake a connection with the salvaged piece, salvage any water tight shroud on the wire into the pump or replace it with new.
When you open the electric box on the pump it would pay you to test the pump motor with a mega, to see if the motor is down if it is need I say any more.
When you have finished the repair or what ever, it might be an idea to store the pump , either repaired or replaced inside a metal box and put some rat poison baited traps around, also leave a couple of Asprins out for the rat in case it get guts ache.
Mar 11, 2014 | Plumbing
Protect mode
This occurs when positive and negative terminal is short circuited. In other words, check your each speaker wires if 2 intertwined wires are connecting to each other creating short circuit. This could also happen on the back panel of the receiver where wires are plugged into each terminal. Basically, PROTECTED MODE display occurs to protect system from getting harmful internal damage. Hope you discover the culprit wires.
SS.
Nov 07, 2013 | Sony STRDH520
I have an old Sony SS-TS51 SYSTEM but have no remote to program it. Where can I find a replacement remote. Thanks for your time, Diane
The Sony SS-TS51 is just the speaker set. What's the electronic part?
Try http://www.remotes.com/ with the unknown model number, then zoom in on the picture of the original remote provided on the site to get the actual remote model number for subsequent web searching if necessary. Also check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Aug 30, 2011 | Sony Dream Home Theater System, DAV-DZ120...
Can you tell me if a receiver Sony 7.1 works with speakers ss-mf515 and What happen because I use the higher volume and the speaker sound low?\r\nWhat kind of receiver works with the speakers I mencioned...
Since you don't name the receiver we have no idea of its audio power or compatibility with 'standard' 8-ohm speakers.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-SS-MF515-Speakers-manual/id/956ci160/t/2/
Any normal standardized NOT-all-in-one-hi-fi-in-a-box amplifier will work with these speakers.
Apr 05, 2011 | Sony SS-MF515 Speaker
We recently bought new speakers and the wires have
Most speakers that are not part of a proprietary system of original design will accept a spade and/or a banana plug, likewise with amplifiers and receivers.
You can also bind your strand wires or solid core wire types around the posts and tighten them down.
Feb 19, 2010 | Sony SS-X90ED Main / Stereo Speaker
70 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
