Question about Cell Phones
Phone out of order the phone as no dialing tone
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 157 Answers
Umm... Cell phones don't have dial tones.
Posted on Mar 26, 2011
Will not dial out on pulse on one line, works on second line
try changing phone to tone dialing . one phone line has been setup for Decadic dialing and the other line may be setup for tone dialing.
If tone dialing is working on one line but not the other then get phone company to change the dialing type on the phone line.
Dual tone multi frequency is the technical name for tone dialing and is more efficient than decadic dialing or pulse dialing.
Jan 23, 2016 | Lands Phones
Dial tone nortel phone
It\'s in system programming: feature CONFIG, Terminals & Sets, enter ext #, Prime Line: set to I/C (for intercom dial tone) or Line xxx. It is probably set to None based on your description.
Aug 26, 2014 | NorStar T7316E Corded Phone
Have a vodavi sts and i keep losing dial tone. Have to call my phone provider to reset lines in order for dial tone to get restored
The sts system does not work very well with digital communications. But did you try powering down the system and then restarting it? On some of the cases I have worked on the seem to help.
Mar 26, 2013 | Vodavi Starplus SP7314-08 Corded Phone
Need the instruction booklet for the model # DCT6485-3HS 328E 1203 - We can not get a dial tone
user guides provide details for telephones least in functioning order. A dial tone is attained from a teleconnection agency. For example, new telephones least that are broken would require that a telephone networking company be contacted about establsihing live interactivity. refer from the local networking agencies also attainable from phone books as reference places.
Jul 20, 2011 | Uniden Cordless Phone
Phone dialing like rotary
Press the MENU button until TONE/PULSE MODE shows in the display. Press either arrow key to display the current mode. Pres an arrow key again to select TONE mode. Need the operating guide? You can download/print it here:
http://static.fixya.com/Manuals/G/GE/29385G1_Crdd_B46DA5B853306E0D4070DB3B7B910C90.pdf
Dec 07, 2009 | GE 29385GE1 Corded Phone
No dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Sep 04, 2009 | Vtech Lands Phones
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Dial Tone - Number Dialed does not go through
The problem is possibly the keypad on the phone. Try another phone , preferrably a standard corded phone. If you still cannot break the dial tone, then the problem is with the telephone line (phone company)
Mar 28, 2008 | Lands Phones
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
