Question about IBM x3400 Server
I previously configured RAIF 5 on my new IBM x34000 server, but now i can see. its showing only C: when i check in computer managament it is showing 600 GB unallocated . please help
  • 31 Answers
Even though you set up the RAID 5 you still need to allocate the space to where you want to ie pool, volume etc.
Posted on Mar 26, 2011
IBM e-Server x226 win 2k3. This has 3 Hdd by default with Serveraid-6i.
If you can get into the bios, you should be able to tell your system which drive(s) to boot from.
Feb 18, 2018 | IBM Computers & Internet
Planar fault IBM 3550 M3
Ok, That' s a motherboard issue. You would have to replace motherboard...
Workaround:
1: Set server in minimum configuration(single processor and two RAMs)
2: Remove any PCI cards added in server
3: Turn on server check for issue
If plannar fault appear, you have to replace motherboard..
Thanks
Feb 14, 2013 | IBM x3550 Server
Steps to configure raid 5 on ibm xseries 232
hi,
which material have you ? : CD
which server ? xseries xxx model type ?
If this is the unique SCSI adapter in your system
or the unique seen, you must:
0) download
90p2772.iso 505,085,952 IBM ServeRAID support CD v6.10
or use what you have.
1) Boot from cd (linux) to configure RAID , before install W2K Server
2) run 23k4684.exe (previous site) in another pc and make a floppy
3) boot from W2k CD and press F6 when proposed
4) insert floppy previously made
5) when OS is installed, or from CD or using 23k4687.exe,
install "IBM ServeRAID Manager", to see activity.
Oct 28, 2010 | IBM eserver xSeries 232 8668
In my IBM X226 server 2 HDD became unavailable in RAID 5 configuration. now I have replaced the hard disks and rebuild process is continuing. 1962 operating system not found error message is being shown...
Raid level 5 gives you some redundancy in your raid however it only allows you to lose one hard drive, two hdd lost would not permit to recover from. the parity bit can rebuild one hard drive but not two, sorry your raid might be lost
Aug 15, 2010 | IBM xSeries 226 Server
Firsty my ibm x 236 server is showing 162: configuration error than Re-=booting due to unexpected NMI at F000:FF54
XSERISE 235 TYPE 8671J
1,NO VIDEO,NO BEEP
2,PCI-X SLOT5 POWER LED ON BUT IT HAVE NOT BEEN ABSENT
Jan 20, 2010 | IBM X236 Server
I am trying to install windows2003 on IBM eserver xseries 226, i am not able to delete the C drive and create a new partition
Use IBM ServeRaid software to blow the array configuration away then recreate the C partition.
Serveraid is downloadable for IBM Support
Jun 09, 2009 | IBM xSeries 226 Server
New install scsi hard disk no detect in ibm x3400 server
you will need to add the new drive to your array bbfore it will how up to be formated do this throught the array configuration util
Regards Al "alstech"
May 26, 2009 | IBM x3400 Server
In IBM x236 server, one swap drive amber led is blinking
Please check how the disks are configured?
If mirrored and second mirror is avaliable you can
replace the disk. (It is the same if the raid5 configured.)
You can download the Hardware Maintenance manual from ibm to
help you in the disk replacement process:
ftp://ftp.software.ibm.com/systems/support/system_x_pdf/25k8114.pdf
Dec 29, 2008 | IBM X236 Server
Xseries 346 wont boot
You don't say whether or not your os is on the RAID 5 partition. Assuming that it is (for performance reasons, this is not recommended) then you should check to see if you have the option of configuring a separate raid configuration on your raid card (e.g. do you have a card with more then one RAID channel?) If this is so, I would create a separate RAID 1 array and install the OS just on that. Then you can mount the RAID 5 array with your data intact. Once you're up and running, you can remove the old OS partition, as it's no longer needed.
Apr 02, 2008 | IBM xSeries 346 Server
IBM x3400 Server Logo
77 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
