Question about Biostar 945GZ-SE Micro Socket 775 Motherboard (945GZM775SE)
My mother board switch not worked - Biostar 945GZ-SE Micro Socket 775 Motherboard (945GZM775SE)
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 13 Answers
Dear there can be many reasons -> Faulty fan that can fail to cool your machine.> Faulty power supply.> It might happen your the power plug in from the case's power switch hooked up to the wrong pins of the motherboard.> You can if you are confident have a look on those parts and fix those pin again or better to look for a service center.
Posted on Sep 22, 2011
Why doesn't my evaporator fan in my refrigerator come on?
Some evaporator fans are controlled by a door switch that prevents fan from running while door is open. Switch is usually located in the area near door front and is either a push button or rocker type. If no switch there could be a control board that is defective. Those refrigerators that have a main mother board control system run all components through that mother board. Hard to tell exactly with out a brand and model number.
Jun 29, 2015 | Frost Refrigerators
No beep at start up
Could be a grounding issue. Remove the mother board from the case, and place on a piece of cardboard. Plug in the power supply, memory, monitor and power switch if it will reach (if not then you will need to short the jumper were the power switch plugs in with a small screw driver). Once set up, power on the mother board, you should get a no hard drive error, since we did not plug it in. If this does work, you will need to go the hardware store and pick up some rubber or paper washer to place between the mother board and the case.
Feb 22, 2012 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
When i press power switch, mother boards power became off.
mother board problem.. u have to change ur mother board or u can do 1 thing just open the restart connection.form the mother board.
Mar 29, 2011 | Intel D845GVSR Motherboard
My mother board is intel 845gvsr,it not coming any display,before days it's working properly.but now it's not working,even bios settings also not showing.some times it's working but only 5 to 10 min only...
just a thought have you checked that its not shorting out on the case? when you installed the motherboard did you put in the spacers?
if you have then i would suspect the psu check that the fan it running when you switch it on
John
Feb 07, 2011 | Intel D845GVSR Motherboard
Power switch turns on and off
that would work if you want a costly bill. Try this before dishing out cash, the problem is the switch that tells the board to turn on and of is bad and a cheep quick fix is to open the back of your TV(#15) (unplugged of course)and remove the hex(#10) screws to the mother board look under TV tube and you will see the switch board,remove both hex screws(#10) and pull the switch board out,follow black cord to mother board and pull cord out of its port. know find the word KEY also #2 on the switch board, should be the red wire. cut this wire and be sure there isn't any bare wire showing at your cut, a piece of black tape will help this. reinstall the switch board and mother board and back of TV . you should be all good to go
Jun 26, 2009 | Televison & Video
Can not find heat sink switches on motherboard emachine t2862
Heat sink switches? I have to assume that you're talking about a dead mother board but the fans and the LED on the mother board are OK? This is a classic eMachines problem. Their power supplies glitch and take out the mother board sometimes the power supply goes bad too.
Mar 24, 2009 | E-Machines eMachines Desktop PC
Fujitsu air conditioner AST24RSG-W
Might be the capacitor. If it swollen or leaky it bad Kimosabe
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 27, 2009 | Fujitsu 24R1 Air Conditioner
My model 1621 radar will not power up
I had exact the same problem with my furuno 1621, Furuno in Netherlands also say needs new mother board (650 euro!)
Problem is fixed
Problem is not the switch, but an Elco on the mother board. it's the small elco on the Mother board Cost just a few cents!
I hope You can fix Your radar too.
Erik Jansen
laptopej@zeelandnet.nl
Nov 12, 2008 | Furuno 1715 LCD Radar System GPS Receiver
My computer is not working
have u tried to boot into bios switch it over to optimal settrings or default settings and save and try to reboot
Aug 17, 2008 | Asrock 775i65GV Motherboard
Biostar 945GZ-SE Micro Socket 775 Motherboard (945GZM775SE) Logo
42 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Alun Cox
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
