Question about Samsung HLR5667W 56" Rear Projection HDTV
I have a vertical line in the middle of the tv it has what looks like pictures how do I resolve this at home
    Scholar:
  • 90 Answers
Hi there, seems you have a defective Vertical IC. If you can locate this 8-10 pins mounted on heat sink and has label LA 7837 or alike. try to replace this. defective vertical IC somehow manifest as horizontal line in the middle of the screen. it has picture but cannot adjusted to occupy the whole screen. Hope this help, please rate and vote. good day
Posted on Mar 26, 2011
Our Phillips flat screen TV picture is split down the middle vertically. One side shows a mirror image of the other side, and then sometimes one side is a lighter shade than the other, when it is full...
This may be due to a faulty Timing Control board (TCON board). I had a similar problem with my Samsung LCD TV picture being split vertically down the middle. The image on both halves appeared fuzzy and in reverse (mirror) including the menus. I replaced the TCON board and the problem was resolved.
Aug 18, 2011 | Televison & Video
Samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
May 25, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Picture on RCA TV shrinks to a horizontal line
Sounds to me you have a cold solder joint ( loose solder connection ) on the printer circuit board around or on the vertical chip or on one of the vertical capacitors. You may also have a bad vertical chip or a bad vertical capacitor, but I doubt it since it did come and go. I'de get a soldering iron and some solder and touch up the connections. I will remind you that you need to always excersise saftey by making sure, before removing the back, unplug the TV from the wall, and use care not to come in contact with the large red wire going to the back of the picture tube as the picture tube can be turned off and still store lots of voltage ( up to 35,000 volts). Always stay safe and when soldering, use care not to run solder across places that will make a short.
Good Luck and I hope this helps
Ed Meshechek ( Radio Man )
NC Electronics
Mills, Wyoming
307-266-4675
Dec 19, 2008 | Televison & Video
1993 tube 37" mitsubishi
It looks like the vertical amplifier IC401 is defective. If you have soldering/desoldering skills you can change this part yourself. Also you may have to change C471 (.01UF 50V).
Good Luck.
Feb 11, 2008 | Mitsubishi CS-35505 35" TV
Picture/image problem
Bad solder connection in the horizontal pincussion circuit.have someone resolder.God luck.4tune
Jan 09, 2008 | Televison & Video
White lines
The problem here is with the vertical circuit. Most likely hte vertical IC is bad. Look for a small flat IC attached to a heat sink. It should have about 9 pins or so and be marked LA7837 or something similar. If you can solder, try resoldering the pins first. If that fails to resolve the problem, replace the IC. If you regain a picture but it appears distorted in some way, additional parts will be required. Update this with your results and we'll proceed from there.
Dan
Nov 18, 2007 | Sony KV-32FX20U 32" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
No Picture On Screen and red line in middle.
The set has a vertical problem if the line you mention is from side to side ,if the line is from top to bottom the problem is in the horizontal circuit and both can be repairable,a vertical fairlure is a common problem,the vertical IC goes bad and it takes a safety resistor with him to prevent any more damage,the horizontal is rare but it happens too,if you are familiar with tv service you can change the IC but you will need a service manual to identify the part,you can get a manual overnight if you downloaded it at www.servicemanuals.net,if you are not too familiar you should seek the help of a servicer for safety reasons.Let Us know how it goes or if you need more information.
Nov 01, 2006 | Hitachi 36UX01S 36" TV
Samsung HLR5667W 56" Rear Projection HDTV Logo
Jerry Greenberg
Jerry Greenberg
