Question about Whirlpool LGR5634L Gas Dryer
NO HEAT DRYER WORKS BUT WONT HEAT UP TO DRY CLOTHES IS IT THE COIL OR IGNITOR
    Genius:
  • 1,028 Answers
If ignitor glows probably coils if no glow possible thermal fuse usually located on blower housing ..short white object
Posted on Aug 04, 2008
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
My dryer ia crosley and wont heat,the clothes wont dry,she activate but dont heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
Jul 22, 2011 | Dryers
I have an estate dryer model # egd4300tq the ignitor will light but doesnt stay lit so clothes wont dry
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 14, 2010 | Dryers
May Tag Gas Dryer Model MDG3000AWW - Dry works but no heat, more dry/ less dry lights flashing. Whats wrong? How do I get heat again?
it is either your glow coil or it is your ignitor
open the door and remove the four screws
take the front panel off.
leave the door attached so you can test the dryer
be very careful not to touch any wires while you are doing this
now close the door and turn the dryer on
does the ignitor turn on?
if yes that is good
does the ignitor glow and no flame?
sometimes it will take a minute to show it's problem
if the ignitor glows and no flame replace your ignitor coils
make sure to turn the power off when replaceing the coils
Aug 24, 2010 | Maytag Dryers
The gas drier takes 2 or 3 times to dry everything works fine but wont get real hot
there should be a an opening on the front panel or a piece of plastic that you can pop off to see the ignitor.start the dryer and while your clothes are drying after around 20 to 30 minutes look in the hole and see if the flame is lighting or is the ignitor just glowing and then it goes out without the flame lighting.if this is what's happening and sounds like it is you have bad gas coils.they will work until they heat up and then they fail,when they cool down they will work again for like 20 minutes and then shut down again.this is an easy fix,just take out the two phillips screws that hold the coils down on top of the gas valve,remove the cover and change out the coils.let me know what you find
Aug 19, 2010 | Dryers
Neptune MDG5500AW Gas Dryer: What causes my dryer to dry clothes one cycle but ...
Believe it or not your ignitor is going bad...
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 17, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
GE Dryer has not heat
dryer spins fine but wont heat
Aug 05, 2009 | GE Dryers
Does not dry the clothes.
On the blower housing in the rear is a duct fuse. If the dryer gets stopped up that fuse will blow and kill the gas assembly so I always check that first. Then If that is kosher I check the flame sensor for continuity. if it is open the ignitor and coils won't work. if it turns out to have continuity I next will check the ignitor for continuity. If it is open then nothing can happen right? If the dryer runs and the ignitor glows, shuts down and heats for a short time and then quits then that is the operator coils. mainly the one with 2 wires comes on and stays on most of the time the dryer is calling for heat. the coils come in a pair for $20. On this page I am going to post a better explanation is given with pictures. above the page is a few more links that are helpful. More gas dryer enlightenment
Apr 12, 2009 | Whirlpool LER4634J Electric Dryer
Dryer lights, heats up some but wont relite
Replace the coil packs on the gas valve this fixes 90% of gas dryers lighting intermittently. The bracket comes off and they are sold seperately from any appliance parts retailer.
This worked for my dryer.
Feb 06, 2008 | Whirlpool LGR5634L Gas Dryer
Whirlpool LGR5634L Gas Dryer Logo
145 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
