Question about Garden
Ihave a 630m karcher how do I drain the carb?
    President:
  • 1,489 Answers
You have to remove the bowl from the bottom of the carburetor. Turn off fuel supply from tank before doing this.
Charlie
Posted on Mar 26, 2011
What type/grade of oil are you supposed to use in Florida for the Karcher gasoline powered 3200PSI
10w-30 will be OK.
I use synthetic oil in all my small engines, but it's not necessary.
Check your oil before each use and drain the gas out and run the carb dry of gasoline before any long term storage.
Getting the gas out of the engine when it's stored will save you having future problems.
Sep 13, 2017 | Karcher Garden
Karcher gas washer will not start...have replaced the spark plug and put fuel stabilizer in the gas tank.
Does it have old gas in it? Fuel stabilizer added to old gas is added too late, must be put in with fresh gas. Drain fuel and replace with new gas. Drain carb. also while tank empty and fuel lines if you can. If lucky you will not need to take carb. apart to clean.
Jul 07, 2011 | Garden
Hi i have dell inspiron 630m and i use the win7 as opreating system, ihave problem with video card. the screen resolution. in dell site there is only win xp.
that model does not have video drivers for windows 7. you can still use 7 but you will have problems playing games (including solitare) and watching videos also you wont be able to use some aero features. your stuck with that 800X600 resolution as long as your running windows 7
Apr 01, 2011 | Dell Inspiron 630M Notebook
Ihave a karcher 630m which keeps cutting out please can you help
OIL LEVEL LOW?, CARB NEEDS CLEANED, DRAIN CARB FUEL BOWL CHECK COLOR OF GAS , MAY HAVE WATER OR OLD GAS IN BOWL AS WELL,
Mar 25, 2011 | Karcher Garden
Press. Washer Honda engine gx 390 will not start
did you leave fuel in it from last year, if so remove all fuel from tank, drain carb. (remove float bowl if it doesn't have a drain bolt) put in fresh fuel, check your oil level and you should be good to go. if not, please take it to a qualified tech. for carb. cleaning.
Doc
May 17, 2010 | Karcher G3025OH Pressure Washer
What to do found water in gas tank of pressure
have you drained the tank, and disconnected the fuel lines from the carb. so that the carb will drain? if not you need to get the water out of the carb. the put some rubbing alcohol in the new gas and this should get rid of any residual H2O
Apr 17, 2010 | Karcher 2500 PSI Pressure Washer
Float bowl drain plug stripped, had to buy a new carb. new carb came and new float bowl didn't have the threaded part that what may be the ignition module to screw into. So I took the old float bowl off...
When you replace the carbs on these motors it can take a bit of time for them to start and run. If there is a primer bulb pump it up and keep pumping, this is basicly force feeding the carb until it has the vacumn to get the regular supply of fuel coming in.
Mar 25, 2010 | Coleman Powermate Proforce 6,000 Watt 12...
Ihave a 1982 mercury inline-6-115hp am having carb-boat motor
floats are sticking in the carbs . rebuilding is the only cure
Feb 07, 2010 | Boating
Karcher 3000 psi won't start.
It sounds more like a carb problem flooding and dumping some gas into the oil. This unit probably has a low oil sensor and the gas could be affecting this. I would have somebody look at the carb and find out why doing this, change the oil and try again. I have one that leaks gas because of float problems, that has done it since new, waiting for spring to remedy. Good luck, Also you can go to Karcher.com for a parts explosion and manual if needed.
Jan 17, 2009 | Karcher G3025OH Pressure Washer
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
