Bosch WFL1660AU drum not spinning. - Washing Machines
  • Washing Mach... Master
  • 1,527 Answers
Hello check the pump first it has to pump water out first before it spins if the pump is ok then the module control board could be the cause this controls the motor speed if this ok the brushes on the motor can also cause spins problems hope it helps
regards
shaun
Posted on Mar 26, 2011
Washing machine will not engage drum in wash or spin mode
it sounded like the brushes have gone but you said you replaced them right? usually when the drum stops spinning its because the brushes have completely worn down and there is nothing left are you sure you snapped them into place properly or brought the correct model numbered ones? then are very difficult to get into the correct place I had a very similar problem and it took four attemps to get them in thr right place they are not the most easiest of things to do. if you have then it might be the motherboard electrical component if this is the case you will need a new machine im afraid if you dont have that much disposable funds try the freecycle website the offer free stuff look for you nearest area and take a look
Apr 15, 2014 | Bosch Washing Machines
Drum will not spin correctly
Sounds like the drum bearing is worn out or the rollers that support the drum are worn out.
Feb 13, 2014 | Bosch Neff Beko Dryer 263297
Drum will not spin on any cycle.bosch nexxt 300.
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Washer-Parts/Model-WFMC2201UC13/1794/0153200/50033052/00003?blt=06&prst=&shdMod= If the drum is not turning on any cycle then I would suspect either the belt - Item 308; or the motor - Item 327.
If you are saying that it doesn't go into the spin cycle (but the drum turns in other settings) then I would suspect the control board - Item 333
Jun 24, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Bosch dryer lights up when turn on nut drum does not spin
The drum spins around by the belt surrounding the parimeter of the drum. A tensioner is also part of this system. You may have a broken belt although the belt usually squeals before breaking so I think the tensioner is at fault. The top would have to be removed then the front panel next to gain access to these items
Mar 31, 2010 | Bosch Nexxt 500 Dryer
BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
With only 1 item in Drum my new Bosch WAE24363 will not perform a spin cycle, yet adding more item into the drum then the machine will perform a full spin cycle. Why will the machine only do a full spin...
most modern machines have an out of balance detector to prevent the machine being damaged with a badly balanced load.
with a single item in drum, load will not balance and out of balance detector comes into action and prevents spin
Sep 09, 2008 | Bosch Washing Machines
My Bosch washing machine drum does not spin at all
No, there is no rotation on the drum at all tresilla.
Jun 21, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
