Question about Sony VAIO VGN-N365E/B Notebook
My Sony Vios VGN-N365E is not powering up. I get nothing no lights nothing. The powe suppy had fried so it was replaced but still nothing.
5 Suggested Answers
MDoe
  • 156 Answers
SOURCE: sony vgn-s1xp won't power up
Hi
Follow the procedure below to troubleshoot no power or the VGN-S1XP (VGN-S360) does not turn on.
While following this procedure, note the LED status at each step. This will provide additional information for further troubleshooting.
NOTE: Some computers are designed with hooks above the LCD screen that secure the lid when closed. A switch inside the holes below the touchpad [picture attached] detects when the lid is closed and latched. If the switch is stuck, the computer may not turn on properly. Check to make sure the switch is working properly.
Connect the AC adapter into a known working AC outlet and to the DC jack on the notebook.
NOTES: Do not connect the AC adapter to a surge protector or extension cord. If the DC jack on the computer is loose or damaged, the computer may require service. Some AC adapters have a POWER LED indicator and can be confirmed as receiving power by ensuring the LED is lit. If the AC adapter is damaged or the LED is not lit when plugged into a working AC outlet, the adapter must be replaced.
1. Attempt to turn on the computer. If same, press and hold the Power Switch for 15 seconds and try again.
2. If issue persists, remove the battery; disconnect the AC power adapter; press and hold the Power Switch for another 15 seconds.
3. Connect the AC power adapter. Attempt to turn on the computer. If the computer turns on without the battery, connect and charge the battery for 24 hours.
4. Disconnect all external devices that are connected to the computer. These devices include, but are not limited to, a modem, floppy disk drive, network connection, USB device, printer, keyboard, or mouse. Attempt to turn on the computer.
5. If issue persists, remove any additional Random Access Memory (RAM) that was installed in the computer and attempt to turn on the computer.
6. If same, remove all RAM and attempt to turn on the computer. Note beep codes and pattern.
Ensure to remove battery and disconnect AC before opening up the laptop to remove RAM. Electrostatic Discharge (ESD) precautions should also be adhered to.
NOTES: The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. (In this case, the system board and or other parts may likely be faulty.)
Regards
Mike
Posted on Mar 27, 2008
Geekman
  • 32281 Answers
SOURCE: my sony vaio vgn-n365e screen is Dim
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jul 24, 2009
  • 58 Answers
SOURCE: want keyboard drivers for sony vaio VGN-N365E
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNN365E
Posted on Feb 10, 2010
  • 186 Answers
SOURCE: HOW TO REMOVE THE SONY VAIO VGN-N365E HARD DRIVE
dont mess with it have it done by someone whoknows
Posted on May 02, 2010
Have a sony vios and have no passwords for the bios
try this website, some password are free, and other you have to pay to get the pass;
Feb 14, 2014 | Sony VAIO VGN-FZ470E/B Laptop
Mass storage device driver of sony vaio vgn-n365e for windows 7
The drivers for Windows 7 are not released by Sony. However, my experience says installing the Vista drivers will do the trick. I will tell you which all drivers to install in the computer to for mass storage device. Please install the drivers in the same order:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN365E&upd_id=2653&os_id=28
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN365E&upd_id=2663&os_id=28
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN365E&upd_id=2670&os_id=28
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN395E&upd_id=2818&os_id=28
Thanks!!!!
Dec 21, 2010 | Sony VAIO VGN-N365E/B Notebook
Vgn-n365e will not power up, no lights no noise, how do i test
Need a known good battery and known good charger.
May use a multimeter to test battery voltage outside of the computer (when it's not connected to the computer) and also voltage of the charger when it's not hooked to the computer but is plugged into the wall.
Aug 19, 2010 | Sony Computers & Internet
My laptop sony vgn n365e.but sound is not coming
If you've checked all the settings with your sound driver, and maybe tried to boot another OS (Like ubuntu), it looks like there is anissue with your logic board. However many times it's a broken headphone jack too, so I wouldn't exclude thatpossibility. I work for Sony Repair NYC and we do this repair frequently.
Dec 19, 2009 | Sony VAIO VGN-N365E/B Notebook
Bluethooth for sony vaio vgn-n365e
A bluetooth adapter does not come standard on the vgn-n365e. It is available as an optional component, but unless you ordered this specifically, your machine does not support it. Bluetooth is not just software; if the laptop does not have the proper hardware built into it, you cannot use bluetooth.
The best way to check is to look at the Device Manager (click Start>>Run>>type in devmgmt.msc and hit enter. If you do not see a line that says Bluetooth Adapter, your machine will not support it.
I offer remote control assistance too! - Info@LoganComputersER.com
Nov 20, 2009 | Sony Computers & Internet
I have lost my recovery data(sony vaio vgn n365e).where i can find this?
If the data was on a recovery partition and that sector was destroyed, you will need the restore disk for your system. If you do have it, you can purchase a new one from Sony.
Good Luck
C2Solutions
Oct 18, 2009 | Sony VAIO VGN-N365E/B Notebook
Wireless sony vgn-n365e
ok here is the link to the original sony site and your model laptop.....just scroll down a little you will see a box that says......select an operating system to see files.....click the arrow and choose microsoftxp.
hope that helps
Oct 21, 2008 | Creative Labs Sound Blaster Live! 5.1...
Sony VGN-N365E WINDOWSXP-PRO DRIVERS DOWNLODS
Audio Drivers for the Sony VGN-N365E running XP can be found at:
Device is a RealTek High Definition Audio
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
Wireless LAN drivers can be found at:
Device is an Atheros Lan-Express AS IEEE 802.11g PCI-E Adapter
http://www.atheros.cz/download.php?atheros=AR5006EG&system=1
Modem Drivers can be found at:
Device is a Conexant HDAUDIO Soft V92 Data Fax Modem with SmartCP
http://www.downloadfast.net/download11235.html
let me know if this helps...
Oct 15, 2007 | Creative Labs Sound Blaster Live! 5.1...
Sony VAIO VGN-N365E/B Notebook Logo
153 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
