I need help tld ACU-804 AIR COND I NEED TO CHANGE ITS COMPRESSOR PLZ ADVISE ME HOW TO REPLACE ITS COMPRESSOR WITH OUT WASTAGE OF R 22
5 Suggested Answers
22yooper
  • 828 Answers
SOURCE: My E.G. Air Cond.Compressor/condenser fan
These motors have a wiring diagram on the motor. Make sure you don't have two different speeds connected together.
Posted on Jul 11, 2008
  • 659 Answers
SOURCE: manual for split acu model LP-10091
You will have to go through a distributor or a dealer. Most often, you will have to be licensed by the state to purchase this item unless you can find a bootleg somewhere on the internet. You can find the manual for this on the LG website. www.lge.com
Posted on Apr 18, 2009
relaga58
  • 158 Answers
SOURCE: Need Capacitor Size
try calling technical support of the company
Posted on Jun 04, 2009
  • 116 Answers
SOURCE: compressor of intertherm cond unit MTL-011548BAV
make sure coil and fan are clean and getting good air flow thru the coil and not bypassing it if discharge psi ok air flow problem if high then somthing in unit stopped up some have screens in the liquid line at the coil hope this helps also make sure fan is going the right way! on indoor unit repost psi and temp readings on both lines and indoor and out door temps thanks
Posted on Jun 08, 2009
Help!! Broke a belt on our Jeep Cherokee 4wd 2000. Air cond clutch froze in place need to by pass, what belt do,or can I use
if the ac compressor won't turn even with the engine off,it's not the compressor but the freewheel bearing inside the pulley,
even if the compressor is bad ,changing the bearing will allow the serp belt to turn the pulley.
I'd just change the bearing .
Apr 10, 2011 | Jeep Cherokee Cars & Trucks
Trans feels like its draging a boat ancor help 93 s10 extended cab replaced 4l60e trans (tld code) new fluid and slick 50 old trans cond added 4x4
Your stuck in 4x4 mode or it's only partially engaged. You need to have the transmission checked to see why this is sticking.
Aug 28, 2009 | 1993 Chevrolet S-10
NEED CLUTCH FOR AIR COND. COMPRESSOR 2001 DODGE DURANGO
dealership or local auto parts store. I strongly advise against getting a used one as thereis no garauntee that it will work.
Aug 18, 2009 | Dodge Durango Cars & Trucks
Need help in AC compressor replacement. The existing compressor number is C-SB351H6B and its a SANYO.? What is the BTU rating for this compressor and what would be the replacement with a copeland scroll...
This compressor has a rating of 56700 BTU at 45 deg. F Evap and 130 deg. F Cond.
Your supplier will match a copeland scroll using this rating
Fuji
Aug 03, 2009 | Heating & Cooling
Compressor of intertherm cond unit MTL-011548BAV shorted. Replaced with 4 ton (48,000) complete cond unit. Now, suction line frost back to compressor with R-22 suction pressure too low (50#). Why? and...
Jun 07, 2009 | Heating & Cooling
Air cond dash light works, compressor doesn't go on.
AC's have a low freon switch that shuts off the system to protect the compressor in the advent that you have a freon leak have the system checked for a leak
May 28, 2009 | 1996 Toyota Camry
Rpm drops down when acu is turned on
Are you turning on the compressor (as in turning on the air conditioning) or just the vent? If you're turning on the compressor and the revs drop, that's normal. The compressor is driven by an engine belt, and when it is turned on, it puts additional drag and load on the engine, causing the revs to drop.
Oct 31, 2008 | 1998 Nissan Sentra
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
