Unisonic XL-1149 Printing Calculator (Adding Machine)
My father's adding machine refuses to "feed" the paper. There was a black rubber piece that came out of it that grips the paper to feed it through. Do you know where I can get a replacement part?
Frustrated and trying to help,
BrendaF
I can not get the paper to feed in my Unisonic XL-1149 calculator
Cut paper at a 45 degree angle and load into back slot with angle (apex) of paper to the right of machine when facing it. Be sure to push it thru when loading. You should see tip next to calculator number wheel. Hit the additon sign several times to advance. You may need tweezers to pull paper thru if it doesn't advance by itself.
try this otherwise see the manual and make sure you are not using generic paper roll only use specific paper because the Chinese knock off paper is to thin
Mar 01, 2018 | The Office Equipment & Supplies
How do i fix the paper jamming which happen in my copier machine ricoh 2027at the second,third fourth drawer?
you need to check does the sensor on the drawer which is on the right side front of the drawer, does correspond with the paper inside the drawers.
Oct 10, 2016 | Ricoh Aficio Office Equipment & Supplies
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
Need a user manual for adding machine EC-3017
The feed roller turns to mush on these old calculators. I suspect that is the problem with this one. You might get it to work if you replace the mushy roller by a new piece of rubber tubing. However, you have to be mechanically inclined to take the printer apart enough to get to the mushy roller. I have this exact same calculator in my hand right now and when I folded printer paper on a 45 degree angle and forced it through the printer until I could pull it through, the paper was gooed up down the center where the mushy roller rubbed off onto the paper. The calculator still works great electronically!
Dec 13, 2013 | Radio Shack Office Equipment & Supplies
Having a problem with prtinter it's not feeding right keep feeding from right side...tried putting one paperat a time but still not feeding right....PLEASE HELP...
Using high cotton paper causes cotton dust build up making it hard for the rubber rollers to grab the paper. Check inside for paper dust build up. If so, clean rollers with a window cleaner.
Another problem is saving too much money on paper. There are some very thin light weight papers which the printer rollers have a hard time gripping. Most printers do well with 22 lb paper. Otherwise you may need to put a piece of scotch tape under the roller so the machine can grab the thinner paper.
Also check your side paper alignment guide in the tray. As well as making sure your paper is sitting all the way back/down in the tray.
Apr 13, 2011 | HP PSC 1610 All-In-One InkJet Printer
How do you put the adding paper into the machine? My machine is a EL-1197iv
Never insert paper roll if torn. Doing so will cause paper to jam.
Always cut leading edge with scissors first.
1) Insert the leading edge of the paper roll into the opening. (Fig. 1)
2) Turn the power on and feed the paper by pressing . (Fig. 2)
3) Insert the paper roll to the paper holder. (Fig. 3)
DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
DAMAGE TO PRINTING MECHANISM.
Jan 03, 2011 | Sharp EL-1197PIII Calculator
Paper jams after first sheet prints. Tried adding more paper and then taking paper out. Nothing is working. No other sheets are jammed in the printer.
Poor quality paper can cause feed problems as the edge may be poorly sheared causing the sheets to stick together and often leaves fibers on the rollers which reduces their grip. Always 'fan' paper when replenishing to loosen the sheets.
Also, printers with heavy usage will occasionally needs the rubber pickup rollers cleaned. Don't use alcohol since this can dry out the rubbers surface complicating the problem. I have used naphtha to remove the built up paper fibers successfully.
Dec 03, 2010 | Brother HL 5250DN Laser Printer
PAPER LIGHT FLASHING RED BUT MACHINE HAS PAPER IN IT
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 07, 2010 | Brother HL-2040 Laser Printer
Open Questions:
439 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
