Question about Panasonic TH-42XVS30U 42 in. Plasma HDTV
Panasonic plasma tv model:TH-42PV8AZ no power found Q406 rjk5020 short and f401 and 402 8a fuse short,please help what can i do cannot find Q402 RJK5020 can you give me a substitute number to use or whats the remedy.
4 Suggested Answers
SOURCE: I need the transistor RJK5020
Go to newark electronics on line.
Posted on Oct 23, 2010
  • 25 Answers
SOURCE: rjk5020
Vizio there ausim! or replace the fuses after you unplug it
Posted on Jun 26, 2009
SOURCE: where can i get a RJK5020 IN USA
ORDER FROM PANASONIC PARTS DEPT. - THE PART NUMBER IS:
B1DEKQ000004
MAKE SURE (!) YOU USE THERMAL HEATSINK COMPOUND, AND YOU DON'T DAMAGE THE SILICONE INSULATOR IN ANY WAY.
Posted on Jun 03, 2010
My tv has no usb port so how do I connect my computer to my tv
Best way to connect a computer to a TV is with an HDMI cable. If your computer doesn't have an HDMI output, you can get a USB dongle with an HDMI connector.
Aug 17, 2017 | Panasonic Televison & Video
Can your power cord be bad on a panasonic plasma tv to cause it to turn off and not start again and blow a fuse on pb
The main power regulator board will have some shorted component/s on it. Normally, these boards to plasma TVs are irreparable. Card base replacement should be done.
Jan 29, 2013 | Panasonic TH-C42HD18 42 in. Plasma TV
TNPA4221 - Television won't turn on, fuses and transistors good
If TV is completely dead you have either a bad power or a bad main board.
Talking form experience I'd go with the power board first.
The alternative is to make sure the power board outputs the normal standby power to the main board and see that the main is not responding to command. That would point to the main.
The fact that Q406 is not shorted does not mean it is good let alone that the power board is good; while the most common issue there it is definitely not the only one that can happen.
You can send in the board for inspection/repair if interested although you're probably better off just buying a replacement.
Oct 08, 2012 | Panasonic TH-42PX75U 42 in. Plasma...
Ten blinks on my th-42pz80u panasonic. how can i fix myself
You have a power supply issue. You will need to replace the power mosfet Q406 and likely one or both of the 8 Amp ceramic fuses. The Mosfet is under a heat sink which will also need to be removed. It doesn't hurt to double check the rectifier diodes while you have the heat sink out of the wqay. They are probably fine though. There are also two 10 ohm fused resistors. They are the two small white ceramic boxes R410 and R413. One of these may be open as well.
Parts can be found on ebay.
Aug 27, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Panasonis 50" plasma, both fuses keep blowing when
This is a dead short, check power supply for diodes bad or zeners
Mar 08, 2011 | Panasonic Viera TH-50PX80U Plasma TV
Sat went out lost power. can not get tv to turn on. checked outlet (fine) sat powered up. no tv power.
When this happened it probably took out Q406 a switching field effect transistor on the power supply board along with F401 an 8 amp Slow Blow fuse. The FET will have to be soldered in if it is bad. If the fuse is blackened, it is almost certain that the FET is shorted as well.
Jan 30, 2011 | Panasonic TH-42PX60U Television
While watching TV the screen went black as if it is not turned on at all
replace fuse 8 amp and Q406 part number RJK5020 both on the power supply board
Sep 18, 2009 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
TH-42PX60U red light blinks 10 times wont come on
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Dec 08, 2008 | Panasonic TH-42PX60U Television
Panasonic TH-42XVS30U 42 in. Plasma HDTV Logo
404 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
