The belt is off my Hotpoint WMA33 Front Load Washer what should i do
    Brigadier General:
  • 6,277 Answers
It has come off for a reason but don't just put it back on- purchase a replacement!
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
Hope this is your problem solved.
Good luck,
John C
Posted on Mar 26, 2011
Testimonial: "Thankyou but there are no screws on the back to take it off."
  • tboults Mar 26, 2011
    However all the other information was very good.
  • john_cross Mar 26, 2011
    Ah, makes it difficult, doesn't it! The top must come off on your model, sorry. I wrongly assumed that as you could see it had come off ,you had removed the 'back' ;-0(
    JC
Overfilling on rinse and spin cycle
Possible that the water level sensor which is a pressure sensor has failed You can check this out on this link below:
click on Pressure sensor.
Jan 14, 2013 | Hotpoint WMA33 Front Load Washer
Belt has come off when i look in the back how do i fix
(repeat solution!) Hi from retired Englishman in SW France,
Good luck,
John C
Mar 26, 2011 | Hotpoint WMA33 Front Load Washer
My machine won't spin. The belt is OK. Any ideas? Brushes possibly? Thanks, Ian
Could be brushes, only way to be certain is to remove motor and check them for wear.
Replace if less than 4 or 5mm long.
Could also be blocked pump filter.
To check , remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Dec 23, 2010 | Hotpoint WMA33 Front Load Washer
I need to replace the 2.5m grey overflow pipe on my Hotpoint WMA33P
Any good diy store should have this. access is through bottom rear panel
Jan 31, 2010 | Hotpoint WMA33 Front Load Washer
Hotpoint WMA33 washer - door won't open
Problem seems to have corrected itself! I tried another slow spin cycle, waited a reasonable interval for the Door Locked light to go off, then when it didn't I switched the power to the machine off. I tried squeezing the door catch a few times and pressing the door downwards, then left it. Some time later when I went into the kitchen the door was open. I washed a small load this morning and the machine worked normally. Fingers crossed, it's ok now.
Oct 07, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint door not locking
i think the problem from what you saying come from { a water level swith} because it contol also the door from opening when the water is still in the drum so it may need to change from the begining >
thanks
Jul 09, 2009 | Hotpoint WMA33 Front Load Washer
Invalid friend needs User Manual for his Hotpoint 1300 Aquarius Extra WMA33. Can you please help>
Hello.I can help with your request.
In the browser bar type in-
hotpoint user manuals
In the drop down list on the left click on
manuals-user guides-handbooks-hotpoint service
In the search box, enter the model number of washer, and down load the instructions.
Please leave a fixya rating for my solution .
Thankyou.
Jan 30, 2009 | Washing Machines
Wma42
This usually indicates that the sensor which determines that the door is shut properly could be faulty.
My WMA33 does this occasionally. I manually push the door in and up slightly with my knee - and then start the wash cycle. This seems to work every time.
Failing that you will need to replace the door sensor. A call to hotpoint may help.
Jul 04, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wma 34 front loader will not spin
Open the rear panel and check for a broken belt and whether the motor spins. In case both are OK it could be a bad capacitor issue as well. Good luck!
Nov 28, 2006 | Hotpoint WMA33 Front Load Washer
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
