Question about Samsung B5722 Cell Phone
How do i set up the email for use on this handset please
Set up email, wont acknowledge,vant find server,etc. Cant sync aol email, cant use any email onthis????
AOL password or not receiving the AOL password reset message here is a support team available around the clock where you can find that solution. For other any information talk to our technicians because we give you great support only at this contact number +1-844-205-0712.
http://www.aolemail-support.com/
Feb 26, 2016 | Cell Phones
What is the handset configuration setting?
The Handset Configuration Manager is an OTA Configuration Solution in Telecom Consultancy, for all types of Mobile, enabling Mobile Device Configuration settings to be sent automatically at the right time this ensures that customers have access to Data Services immediately, always, no matter why or when they change Handset.
The Handset Configuration Manager will provision Device settings including GPRS, WAP, MMS and Email, using the industry standard OTA provisioning protocols enabling the delivery of settings for a broad range of Mobile Terminals.
Ensuring End-to-End QoS
Using the Reach server Subscriber Capability Management rules, Handset Configuration settings can be sent automatically based on the history of the Handset observed on the network. e.g. only when the Handset is used for the first time. The Reach Server checks to ensure all corresponding Network Services based on the capabilities of the used Handset are also activated.
May 04, 2011 | Computers & Internet
My Sonim XP3 Quest Pro write sometimes fileerror.return when I have an incoming call up and it is not ringing
Hi Riisbjerg, you could try to reset/clear flash the phone. That should take care of the problem, but it also erases ALL settings and phone book entries from the phone, so it is best to make a backup of the phone bookwith the PC tools software.
The software can be downloaded from http://www.sonimtech.com/support/downloads.php
Reset: Please try to reset the handset memory as below:
a. After Powering ON the phone
b. press #20070114# from phone idle screen and press dial key.
c. Message comes up as " Do you really want to clear flash? "
d. Select OK. After reset is finished, you can see the message "Switch off the mobile by any keys".
e. Switch the phone off, then remove and reinsert the battery and Power ON the phone.
Once done, please restore the handset to factory settings:
a. Power the handset on
b. Using the menu buttons, go to Settings (General Tab) -> Default Settings.
c. Press the OK button to confirm
d. Power the handset on again
If this does not help, please send an email to the Sonim support team: support@sonimtech.com
Thanks!
Andreas Sonim Customer Service
Jan 15, 2011 | Cell Phones
Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Feb 16, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
Unlock but cannot set the email
If the handset is unlocked.Then you can contact your operator (customer service) please provide the correct information "email id " and "password" so that they can integrate email for you.
Nov 08, 2009 | RIM BlackBerry Curve 8310 Smartphone
Cannot stop Searching message flashing on screen
I emailed tech@doro-uk.com and within two or three hours got a helpful email suggesting the following:
In the first instance please try disconnecting the power to the base station and removing the batteries from the handset for 15 minutes or so. Then reconnect everything and check if this has resolved the fault. This will re-synchonise the handsets to the base station.
The problem is now resolved.
Thanks.
Apr 09, 2009 | Lands Phones
Motorola c168i at&t network pin blocked unlock code f
i also happy a motorola c168i and it is asking for network pin and now it says network pin blocked my imei number is #011460008648589 please i get this phone as a gift and i cant use it i need your help my email address is rhn_campbell@yahoo.com thank you i am waiting your reply god bless you.
Mar 30, 2009 | AT&T Motorola c168i Pay-As-You-Go Cell...
LG KG800
PHONE UNLOCK PROCEDURE
Please follow the instructions below to unlock your LG KG800 handset:
1. Insert a Vodafone Australia working SIM card.
2. Ensure the phone is charged and then switch the phone on.
3. Enter 2945#*7101# while in standby mode
4. Select Menu, then go to Settings > Security > SIM Lock > Network
5. Select Deactivate and enter the 8-digit NCK unlocking code provide for your handset..
6. The handset will be unlocked automatically and will display "Done".
Feb 24, 2008 | LG KG800 Cellular Phone
Samsung B5722 Cell Phone Logo
49 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
