Question about Beko 324250WN 28" TV
BEKO TV. MODEL NR32WLH530HID 145 WATT WHEN SWITCHED ON AT THE TV OR WITH THE REMOTE CONTROL PICTURE AND SOUND COME ON. PICTURE GOES OFF AFTER ABOUT 3 SECONDS SOUND STAYS ON. WHICH CIRCUIT BOARD DO I CHECK ?
  • rwd1552 Mar 27, 2011
    Thanks for your help, would it be possible to down load the circuit diagram, service manual for this set, for which i would pay?
    Thanks again,
    Rich.
    Hi jdvillanueva,
    Thanks for your help, what is the best search link to use would be helpful in the future.
    many thanks,
    Rich.
  • 2,098 Answers
Hi rwd1552,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to troubleshoot the symptoms.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 26, 2011
  • 1 more comment
  • Jdvillanueva
    Jdvillanueva Mar 26, 2011
    I've suspected that the fault is coming either #1 or #2.
  • Jdvillanueva
    Jdvillanueva Mar 27, 2011
    Hi again, I've try my best searching your service manual on my link but I can't find one. Your model no. is currently not yet available...
  • Jdvillanueva
Beko HDMI no sound
The HDMI audio should be controlled by the video driver. You may need to change the audio output to get the TV speakers to get the audio from the HDMI signal. Open the Control Panel (Start > Control Panel with Windows 7 and Vista) and go to the Hardware section. Find the Sound section and click on the Manage Audio Devices link. In the Playback tab, right click on HDMI Output and try to make it the Default audio device. If you see a test option, check if you hear the audio from the TV speakers.
For laptops, the usual default audio is the built-in speakers.
I hope this helps.
Dec 31, 2017 | HP HDX16t Premium Series Notebook
My 32in beko tv keeps blinking and will not stop. The sound And picture is still good the screen Just goes black every other second Model nr 32WLZ530HID Service info Ix-Id tv...
It sounds like the backlight inverter circuit has developed a fault. This can usually be cured by changing some transistors and capacitors, or it could be a poor solder joint.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 22, 2011 | Beko Televison & Video
Hello i need codes for asda's universal remote model URC20-D1F so i can sync it with my BEKO tv please can you help?
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
Dec 27, 2010 | Beko 142746 TV
Beko fst.nicam.fastext
LOST THE ROMOTE FOR THIS T.V. GOT A ONE FOR ROMOTE CONTROL BUD ... BUT THE ONE FOR REMOTE CONTROL IS ASKING FOR THE T.V DEVICE CODE COULD ANY 1 HELP ME OUT THERE ??
Feb 16, 2010 | Beko 324250WN 28" TV
Picture problem with Beko 32WLH530HID LCD TV.
did you ever sort this as ive got the same problem
May 27, 2009 | Televison & Video
Technika tt-16 universal remote control codes for a beko tv
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
Nov 10, 2008 | RCA Universal Remote Control
Beko tv
I know its a long time but could be the high value Cap. careful though high voltages stored in these babies can kill you. even switched off for years.
Aug 27, 2008 | Beko 324250WN 28" TV
TV failure
I would say it is in the power supply circuit. check the 145 v line I do not suspect the problem in the video section.The 145 volts feed to the flyback.
Aug 28, 2006 | Panasonic CT-32SX12 32" TV
Beko 324250WN 28" TV Logo
146 people viewed this question
Top Beko Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Marvin
Marvin
Are you a Beko Televison and Video Expert? Answer questions, earn points and help others
