Question about Whirlpool Calypso GVW9959K Top Load Washer
Cycle running for hours
Every so often, my washer stalls out. At first, it seemed to happen only at the end of a cycle. Now it can happen at any point. The time displayed won't change for as long as 45 minutes. When the load finally does stop, no error code comes up. Usually, the clothes are also still dripping wet because they didn't get a decent rinse and spin.
I had Sears out to check on it, but they couldn't get the machine to repeat the problem. It happens sporadically, so sometimes I can get all my laundry done, sometimes only one load before it acts up again. The repair guy said everything he saw looked fine.
    Novelist:
    Champion:
  • 261 Answers
With the machine off using any button but power and cancel and press 2-5 seconds on then repeat 5 times, you will see 88 and if a code is stored it will flash or if F 2 comes on your panel is shot and cost 100 plus to change.
Posted on Sep 04, 2008
Washer fills on wash won't fill on rinse. Does on old washer and new washer. Checked and plumber said not the plumbing. Help PLEASE
It seems that you are out of cycle; meaning you are washing on rinse phase and the you are not getting water on rinse because you are at the end of the cycle. Try this; set the washer to the end of the rinse cycle, let it spin and stop. then wait 1/2 hour then start a wash you will be at the beginning of a new wash cycle..
Nov 10, 2016 | Washing Machines
How can you get a washer smelling good?
First of all this mainly happens when you use cold water washing, the plastic bowl(s) become slightly porous over time & the dirt from clothes adhere to the area between the inner & outer bowls.
To clean & remove smell.
1. Put washer on hot wash, high level & let it fill with HOT water.
2. Stop washer, put in an old towel.
3. Add a bucket of hot water (This allows the water level to be above the scum mark inside machine.
4. Add washing soda to the bowl (double the amount it says on the packet).
5. Start washer & allow to run to the end of the first wash cycle.
6. Stop washer & allow to sit for a few hours.
7. After the few hours, start washer & allow it to run the rest of the full cycle.
you can do the same procedure with Vinegar.
you may have to repeat procedure a few times.
TO PREVENT THIS FROM HAPPENING AGAIN YOU NEED TO DO THIS PROCEDURE ONCE EVERY 3 MONTHS.
The worst case scenario, you will have get a technician to remove the inner bowl & manually clean these areas.
Apr 27, 2014 | Haier HLP21E Top Load Washer
John Deere 3000psi pressure washer stalling
Mine is having the same issue...I googled and found this with no answers. I'll update if I can find a cure on my own...
Have you checked your oil level?? Small engines have a cut-off switch if your oil is low...mine is topped off so this is not the solution for me..but it could possibly for you.
May 01, 2010 | Garden
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire dishwasher won't end cycle - will run on and on for hours. Sometimes it cycles through, usually it just endlessly washes and rinses. I have to CANCEL the cycle, which causes the dishwasher to...
I would say the resettable thermostat has failed. There is a thermostat which senses the water temperature, and when it fails, it causes the dishwasher to run constant. Replace the thermostat underneath the dishwasher and that should cure problem. Part number is 154290204 (I know the number off by heart, that's how often it happens!)
Apr 07, 2010 | Frigidaire 24 in. FDBB540 Built-in...
We have a WGL 10 US model F&P washer. Most
Are you waiting long enough? Ours seemed to stall but eventually would start up again. Have you tried diagnostic mode? email me at Yahoo.
Sep 01, 2009 | Fisher and Paykel GWL11 Top Load Washer
All of a suden the 20 amp circute breaker in the service panel was thrown. I only had the washer running on that circut. i HEARD A POPING SOUND WHEN THIS happened I thought it was the sound of the breaker...
Check you motor coupler by tilting machine back so you can get under. Look under machine, around where the center of the machine was. If you see a black powder, you most likely have a bad coupler. You may even find pieces of black rubber.
Please rate solution
Aug 27, 2009 | Washing Machines
Hotpoint w440 washer/dryer keeps repeating cycle load?
Hi there, I've got a Hotpoint Aquarius washer / dryer and this has just started happening to me - it seems to get to the end of the cycle then repeat itself. However, I do not seem to be able to cancel the cycle, or am I able to switch it off. It's been going for about 4 hours now. Any ideas?
Feb 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Cycle seems never-ending
on the ECO 50 cycle dish washer will not stop. have had to switch it off, when try to restart it automatically goes back to the ECO 50 programme. Can you please help. The Serial No. is ADP 2440 WH.
Nov 24, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
How do I know when it's done?
TAKE NOTE IF THE WATER HAS DRAINED OUT. RE START THE CYCLE ONCE MORE AND IF IT HAPPENS AGAIN, THE TIMER CONTROL IS DEFECTIVE.
Jan 10, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
82 people viewed this question
Dan Webster
Dan Webster
Sal De
