Laptop was in checked suitcase on flight home. Now when I turn on the power I get no display and appears no boot up is taking place.
  • 17,130 Answers
I think I had answered this before. So please remove off the battery and reset it after some time.
Check your Bios battery , check the charge on your battery.
Posted on Mar 26, 2011
How many luggage bags is one person allowed?
The common standard seems to be one suitcase of 23kg in weight for the standard class ticket. There seems to be an upper limit of 32kg on excess baggage ( the total weight of the luggage).
On some airlines the excess above 32 kg is deemed as cargo and has to go by a cargo plane .
suggest that you look up the particular airline web page you are using and looking up their bag limits to be absolutely certain !
as size limits on the suitcase also may apply.
Weight is very important on aeroplanes as too much weight means the plane does not achieve sustained flight at take - off .
Jan 05, 2017 | Luggage & Travel
TPSA left video on
Check if you can take pictures , if you can take picture the same and tranfer them to computer, then it is either a faulty lcd display, or the display cable out of place
Jul 29, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
What is the telephone number for United Airlines?
Really? You got on a computer, found this site, and figured out how to put in a question, but can't Google "telephone number for United Airlines"? 1-800-864-8331
Jul 11, 2016 | Computers & Internet
I need a pair of 4 wheels for my large Murano suitcase..where ??
Hey Carol, You might get them from Ebay...I hope this helps...
Apr 02, 2016 | Luggage & Travel
I have a HP Pavilion g series laptop. The laptop was working fine, I closed the lid for a few minutes and it turned itself off and will not come back on. WHY?
If your laptop won't turn on, you could have any number of problems. The problem might be a genuine power issue derived from either battery failure or simply a loose AC adapter. Conversely, it may only appear to be a power failure, and the problem may lie with another component. Errors in brightness settings and LCD display malfunctions can both make a laptop appear to be powered off, and all these problems will need to be corrected. Look at the battery indicator light on your computer. Is it on? If so, check your brightness settings. If your laptop appears that it is not on, it may in actuality have lowered brightness settings. If the brightness setting is at its lowest setting, the laptop screen will be completely dark, and the laptop will appear to be powered off, even though it is not. Try cranking up the brightness settings. Check your AC power adapter. Is it snugly plugged into the wall or surge protector? Make sure the connection is made and it is not loose. Also, try connecting the power adapter into a different wall outlet. Check the status of your laptop battery by considering how long you have had the same battery. Most modern batteries are only good for about 1,000 full charges. After that point, the battery can and eventually will greatly deteriorate. Replace your battery if necessary. Replace your battery by powering off your laptop and then flipping it over and locating the battery cover outline, which will be near the bottom back of your laptop. Remove any screws with a Phillips screwdriver and pop off the battery cover. Slide out the old battery. Put in the new battery by sliding it in until it clicks, and then replace the cover. Consider replacing your laptop monitor. Your laptop may power on, but if the monitor display does not work, it will appear to be off and you will not be able to operate the machine. Check to see if your current LCD display works by plugging your laptop up to an external monitor using a VGA cable. If the external monitor displays your computer contents, your computer motherboard and underlying systems are still working, but your display will need to be replaced. Replace an LCD display by removing the screws around the bezel of your current display with a Phillips screwdriver. Pop off the bezel carefully and remove it. Then, locate the screws on the two metal brackets beneath the bezel and on either side of the display, and remove these too. Disconnect the inverter cable, which is plugged into the inverter. The inverter is located just beneath the display, at the bottom-center of the laptop. Then, pull back and slide out the old display, and replace it with the new. Put the metal bracket screws back in place, reconnect the inverter cable, and then pop the bezel in place. Replace the bezel screws. Hope this helps.
Jan 21, 2013 | Compaq Presario CQ60-220US PC Laptop
Own a HP Compaq 6710b and does not start when pressing power button
Jan 20, 2013 | HP Compaq 6710b Notebook
It will not turn on
Jan 16, 2013 | Sony Vaio Pcg-7153l Laptop Webcam
WHEN SWITCH ON MY TOSHIBA LAPTOP THE SCREEN BLANK ...
Alison the first step you need to take is to try to prove whether it is just the laptop display that has failed or whether it is more serious than that.
If you have access to a separate computer monitor, i.e. on a second desktop computer, then try connecting this to your Toshiba laptop and see if you get any information posted on the monitor when booting the laptop.
If you do see the normal boot / start-up messages being posted, then you have shown that the laptop display is at fault and you will probably need to take the laptop to a repair shop.
If you don't see any boot / start-up messages with the external display connected, then you have a more fundamental problem with the laptop.
Check to make sure that you do not have any CD / DVD / Diskette or USB devices connected to the laptop, that it might try to boot from. Listen for any beeps from the computer speaker when you initially turn on the laptop, and check for any LED lights flashing to show that there is any internal disk activity, and that the power LED is lit
If you are seeing LED lights, then there could be a problem with the Operating system (Windows XP?).
If you are not seeing any LED lights, then again, it sounds likely that the laptop system board may have failed - you would need to take it to a repair shop for further investigation.
You could try removing the laptop battery and then connecting the power supply to see if that makes a difference - I have seen laptops that would not boot with a failed battery in place, but which started Ok with it removed.
Jan 01, 2012 | Toshiba Computers & Internet
After flight home, laptop will not boot up or give any display, althought the power does come on.
Please remove off the battery and keep aside and let the voltage on the PC die off, press all keys and main power. Now after about 30 minutes reset the battery. if this has passed through any scanning device , it could have created some errors specially if this was in standby/hibernate state. If not there are errors in the OS or a possible failure of the memory.
Please also check the bios battery that is in the laptop... check on the underside.
Mar 26, 2011 | Computers & Internet
Screen not illuminate
Check the power adapter plug with a multi-meter, the voltage reading should be slightly higher than the voltage that is printed on the label on the bottom of the adapter.
If the voltage is incorrect or near to zero then you have a faulty adapter and you need a replacement.
If the voltage is OK, when you plug the connector into the laptop power socket and wriggle the connector, does the charge indicator light flicker but not stay on. Then you have a faulty connector or a faulty power socket on the laptop. This can be repaired.
May 27, 2009 | Sony Computers & Internet
Computers & Internet Logo
David Payne
David Payne
