Question about NEC LCD4020-BK-A 40 in. LCD TV
Hi I have a NEC LCD4020 with no image.....well it has the backlight and when the volume button is pushed the volume bar comes up, however i cannot seem to get a OSD or and menu, any help is appreciated
2 Suggested Answers
SOURCE: Problem with my NEC PX-42VP4PA
it goes on for a while and then shuts off after then the colour show not good i need help for this problem
Posted on Apr 25, 2010
My lcd display has just a black screen
If there is no nec logo, the problem is in the power supply/inverter board, one or two capacitors open leaving a small dome shape at the top, "most common" but if power comes on the problem is "inverter transformer or backlight issue"
Mar 20, 2012 | NEC Versa Computers & Internet
Incoming ring tone volume too lowcan i adjust it?
You did not list what phone you have... but on most phones the button on the top right side is the volume control....just push it on one side or the other and a bar will come up showing you the volume level...
heatman101
Jun 25, 2011 | Cell Phones
The only button that works is the remote power button. None of the buttons on the side of the tv work. The volume bar is always visible. The picture works when I'm watching a dvd, but the volume bar is...
Hi check to see if the volume button on the side is pushed in or sticking as this will cause all the buttons to not work as the micro thinks you are trying to turn up the button and thinks this button is depressed.
Dec 23, 2010 | Vizio VW22L 22 in. LCD HDTV
HI? HOW TO PUT MY IMAGE UPSIDE DOWN AFTER A CEILING MOUNT NP210G NEC BEAMER.? THANKS, Noel Belgium.
hi,
1. press menu button
2. select setup
3.go to orientation (This sets your image for your type of projection. The options are:
desktop front projection, ceiling rear projection, desktop rear projection, and ceiling front projection.)
ok,
Dec 17, 2010 | NEC VT47 Multimedia Projector
I get sound on my tv but no picture. not even volume bar or menu
check to see if there is an image on the screen by putting a light close to it if ther is an image replace the backlight inverter
Jul 09, 2010 | LG 32LG30 32 in. LCD HDTV
Screen is black, green light is on. Disk light comes on for a second when power button is pushed, and fan comes on briefly. Otherwise, nothing. Same outcome on AC or Battery or Both. I tried the remove-AC,...
There are approx 6 reasons why this might happen:
  1. The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  2. The panel has died - Need a new panel
  3. A cable has worked itself loose or is broken
  4. The inverter has gone - Need new inverter
  5. Long shot, the bios has got corrupted - Engineer could re-flash the bios
  6. Long shot, Mainboard onboard graphics has gone - Need new mainboard
My personal opinion is that the backlight or inverter has gone - Either way it needs to be opened up to repair it, consult a service centre and get a quote or repair it yourself if your up for it.
Thanks
Sep 05, 2009 | Acer Aspire 3680 Laptop
DiamondPoint V71LCD Not displaying image
The LCD screen may be burned out. There's whats called an invertor board and there is an electronic ribbon strip on the LCD itself. If you look very carefully you can probably see a faint image on the screen. The LCD screen will need replacing. Before doing anything with this monitor, try it on another computer first and if you can try another monitor on your computer. Other than that, there really is nothing you can do but replace the monitor.
Jun 27, 2007 | NEC-Mitsubishi Nec Display Solutions...
NEC MobilePro 780 Screen
A couple of things spring to mind. Have a good hard look at the screen when it goes dark. Is there still an image there but it is really dark? If so, consider that it may be a faulty backlight. It may also be a faulty ribbon cable joining the screen to the main unit, or it may be that the brightness down button is stuck and causing it to lower the brightness. The fact that you are pressing the brighness (up button I am guessing) and it comes back on, may indicate the bright down button is stuck or by pure chance you are pressurising the board in that area causing a bad contact to work, such as power to the backlight or pressure on the ribbon cable. I dont have one of these MobilePro's but I am just going on things I have seen with notebook PC repairs. Hope this helps.
May 25, 2007 | NEC MobilePro 780 Pocket PC
NEC LCD4020-BK-A 40 in. LCD TV Logo
Top NEC Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
