Question about Lexmark Office Equipment & Supplies
I have some paper stuck how can i remove it - Lexmark Office Equipment & Supplies
  • Lexmark Master
  • 17,130 Answers
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Posted on Mar 26, 2011
How do I remove a stuck paper tray
Some useful adivic:
Frequently Asked Questions
Clear paper jams Brother
How do clear paper jams Brother
If you still can't remove stuck paper, it's REALLY stuck. Take it to a repair service. apart of removing all that paper, they should diagnose WHY you got a mega-stuck.
Forced removal might damage your printer
Aug 27, 2015 | Brother MFC 3360 INKJET MULTIFUNCTION...
Paper is stuck/jammed on the drum and I am having difficulty removing the d rum unit and toner
Hi lbestu,
Please Read Tip Carefully :-
Tip: To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
1.Turn off the printer.
2.Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
3.Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
4.Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it
5.Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance or repair
Hope It's resolve all Your HP Printer Problem,
Or
Still having Problem Then follow Us For
Brother Printer Support
Feb 05, 2014 | Brother MFC-7340 All-In-One Laser Printer
My paper keep getting jam and will not go into print
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persists and you see no paper that is stuck in the printer it
May 14, 2011 | Office Equipment & Supplies
I have paper stuck in it and can not get it out
Hi
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Jul 18, 2010 | Dell 1110 Laser Printer
Paper jams
hi,
follow these steps:-
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting theprinter manufacturerfor additional assistance and/or repair.
Thanks!
Aug 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
How do I clear a paper jam?
hi,
Thanks!
Aug 02, 2009 | HP DeskJet 932c InkJet Printer
Paper jams and the light comes on
hi,
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting the printer manufacturer for additional assistance and/or repair.
Jul 13, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
My Officejet pro has a paper jam and I can't release it. Thanks
Jul 13, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
How to remove a paper jam from the vivera paper tray
Jul 13, 2009 | HP Photosmart C7280 Laser Printer
Printer cartridge stalled
# Turn off the printer.
# Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
# Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
# Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
# Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue
Feb 06, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
