Question about Hotpoint Ultima WF860 Front Load Washer
Cycle stopped and f-o5 came up - Hotpoint Ultima WF860 Front Load Washer
    Brigadier General:
  • 6,277 Answers
Hotpoint (Indesit) 'F05' decodes as 'pump blocked' which normally means filter blocked! I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 26, 2011
0-1 mitutoyo micrometer reads E--o5 i have replaced battery and cant make it go away?
A data sheet I got with my Digimatic 572
series scale says:
"Keep the scale unit free from water and oil.
Do not dip or sink the scale unit in liquid.
If E--05 is displayed, wipe the scale surface
with a soft cloth. Apply a slight amount of
low viscosity oil, such as CRC3-36, to the
scale surface to keep out water."
mitutoyo micrometer reads o5 Google Search
Mitutoyo Support
http://www.mitutoyo.com/
Jun 29, 2017 | MADE Computers & Internet
Hotpoint ultima WDD960, My washer dryer has stopped mid wash cycle annd is displayinh F:o5
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • The best thing is to see if it is filling and draining properly
Oct 28, 2011 | Hotpoint Ultima WF860 Front Load Washer
I want to know what type radiator coolant is needed for a 1999 Chrysler LHS?
You need G-O5 type coolant. You can either buy it from the dealer or from
the parts store. Make sure the bottle says "G-O5" on it. Do not use anything else.
Sep 18, 2011 | Chrysler LHS Cars & Trucks
My O5 pt crusier stop in the middle of the road when put on the machine it said the crank shaft sensor so which one do I need to buy the crank or cam shaft sensor?
The crank shaft sensor will be fitted over the front crankshaft pulley or where it can read the electronic signals generated from the flywheel....The way it works is to receive a magnetically generated signal which is transmitted to the management computer system....It basically indicates when the piston is at the ignition point of the engines cycle...As we're dealing with a four stroke engine, remember that the crankshaft makes four revolutions to two of the camshaft....The cam will give its own signal via its own sensor....Both are used to control the spark and firing of the plugs in the correct sequence and at the correct time....If the scan tool said the crank sensor I'd think that's the fault and stick to that....
Regards Johngee10
Oct 16, 2010 | 2004 Chrysler PT Cruiser
My driver side door makes 2 popping noises when I open and close it. o5 chevy equinox. Noise is coming from black arm joining door to car.
Front Left Hand LH Driver Side Door Check Stop Linkage
2005 2006 2007 2008 2009 Chevrolet Equinox
Genuine GM Part Number:15861661
Aug 14, 2010 | 2005 Chevrolet Equinox
How to fix o5 cadallac brakes
change the fluid dot 4 and the rubber stop leaking on the upper pump break
May 24, 2010 | 2005 Cadillac CTS
Where are the spark plugs on a o5 colorado
under the individual ignition coils (the coils are over the spark plug) in the cylinder head.
May 11, 2010 | 2004 Chevrolet Colorado
My hotpoint WD640G has stopped mid cycale and is showing the code? F O5 and will not complete the cycle
Error code F05 denotes pressure switch jammed on full.
Remove the lower rear panel of washer.
Remove the large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Feb 06, 2010 | Hotpoint Aquarius WD640 Front Load...
O5 mustang stop running think fuel pump problem how do I check make sure changed filter looked very dirty turn key on with line off pumps a good stream
check to see if you are getting fuel to the injectors because it does not sound like the fuel pump if you get a good stream
Apr 05, 2009 | 2005 Ford Mustang
VillaWare mini-perk 5120-o5 clear perc top
I have a miniperk 5120-05 that has stopped working.  I will let you have the whole thing if I can not get it fixed.
Jul 24, 2008 | VillaWare Mini-Perk 5120-05 Coffee Maker
Hotpoint Ultima WF860 Front Load Washer Logo
296 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
