Question about GPS
Hi, we have a Oyagi 618 navigation unit that no longer will retrieve the maps. On Main Menu when we select the Navigation option is says "Database failed to load". Media still appears to function - it's just the navigation option. Hoping you can help. Thanks, J
  • dellphee Mar 26, 2011
    Hi, I couldn't tell you. I'm investigating this issue on behalf of my dad - he's devo that it's not working as he lent it to a family member and they gave it back not working :-( I'll check out your link. Thanks, J
  • dellphee Apr 01, 2011
    Hi Shane, I think I have backed up the files. How do I format the device? I have an option to restore - is that the same? Sorry for the lack of IT knowledge... If you could step me through it, I would appreciate it. The device came with the unit, USB cable and vague User's Manual... No CD :-(
  • 668 Answers
It indicates that map is not loaded properly in gps unit. You need to format the device and load the map once again. This will work fine. Connect the gps device to computer and take back up before formatting it.
Hope this helps.
Shane
Posted on Mar 26, 2011
    Genius:
  • 1,622 Answers
HI, when last did you update the firmware ?
https://eshop.horizonnav.com/eshop/product_detail.php?p_id=304
good luck.
I need a users manual for navmii gps navigation software For Windows
https://www.microsoft.com/en-us/store/p/navmii/9nblggh10k57 = software.
Navmii used to have an old manual at http://www.navmii.net/bin/Navfree_UserGuide_v1.0.1.pdf
The link no longer works.
Here are some basics:
Basic Navfree Help
Navigation is easiest if locations are added to Favourites before navigating. To check a location before adding it to Favourites, or find a location near another location:
Tap Menu icon at bottom right of map screen. Tap Navigate on Main Menu. Tap Address or Google.
Type name to find. Done. Tap down-arrow beside item . Tap Show on map.
Check it is the correct place. If so tap down-arrow and Add to Favourites.
Or drag map to required location. Tap on map. Select Add to Favourites. Change name if required.
To enter a route from A to B, when A is not the current GPS location.
Need to disable GPS in Android Settings - Location.
Easiest if A and B are entered into Favourites. Use Google Search or Address to find names and descriptions, then Add to Favorites.
Then tap Navigate on Main Menu. Tap Favourites and select A.
Tap box with Favorites name in it, and select 'Route from Here'.
Tap Menu icon at bottom right of screen. Tap Navigate. Tap Favourites.
Tap 'Route here'. Tap 'Selected' (not Gps).
Tap 'My Route' to see Route on map.
To clear route: From Main Menu, tap Clear Route.
Cant edit or delete (sometimes) Favourites. Use Jota app . See forums.
Still looking for manual, there blog is very helpful which is the link above.
Helpful links,
https://groups.google.com/a/navmii.com/forum/#!forum/android-app
https://groups.google.com/a/navmii.com/forum/#!topicsearch/user$20manual/android-app/CibF963hA5I
Nov 16, 2016 | Tablets & eReaders
How do I get the display to show my drive direction to be straight ahead, not 'NORTH' as being straight ahead?
In the navigation options menu, select Map Options and then Map Mode. Select Head Up, 2D or Head Up, 3D as desired.
Feb 06, 2015 | GPS
How can i use gps in my phone?
When you run OVI Maps on the 5230, the GPS will be activated. You'll have to wait till the GPS receives signals from at least 4 satellites to get a "fix" or "lock" This can take some time depending on where you are. Using A-GPS is an advantage for a faster fix. Read the English manual on page 95 about GPS.http://europe.nokia.com/support/product-support/5230/guides
If you want to use navigation on your nokia 5230 then you need some setting that is neccessary for the navigation on you phone. It is stated as first of all you need to set the internet on your phone through your operator and then do the following setting on your phone
1. Go to the Menu.
2. Select Menu > Maps.
3. Select Options > Tools > Settings > Internet
Just set the following setting in your navigation application
* Go online at start-up: Please set the device to open an internet connection when you open Maps.
* Default access point or Network destination: Select the access point to be used when connecting to the internet.
* Roaming warning: Set the device to notify you when registering to a network other than your home network.
Nov 24, 2010 | Nokia 5230 Cell Phone
My mozilla firefox window no longer shows menu or navigation bars. How restore?
Hi pbqsf
The Menu bar and the navigation toolbar have been disabled. You can enable it by following the steps below:
1) Open firefox
2) Press the 'Alt' key on keyboard (Pressing this button temporarily brings back the Menu bar)
3) When the Menu bar shows up, right click on an empty area right next to Help as shown in the picture
4) Now select the Menu bar option and the Navigation toolbar.
Now, your Menu bar and Navigation toolbar will be up.
Thank you for using Fixya.
Nov 20, 2010 | Computers & Internet
Problem with PCM Navigation
Hi I have a 2006 Caymans S and have exactly the same problem, everything works except the Sat Nav!
In the navigation option menu, it lists 0 satellites being picked up
The dealer looked at it today and replaced the GPS antenna, but didnt fix it. They too mentioned about a new unit...
I will post if I solve it, but if you find out what is wrong I would really like to hear about it.
Dec 15, 2009 | 2003 Porsche 911 Carrera
No results when navigation is pressed to operate
There is no map data or it has become corrupted get the maps reinstalled
Jul 27, 2009 | Nextar X3-03 Car GPS Receiver
Fatal application error
this is a common problem, its caused by corrupt data on the SD card. it happens when the unit is powered down while its saving data. to avoid it you want to shut down using the menu or exit navigation before shutting down.
now, you have 3 options:
Option one: Visit C&C wireless and pay over $100 for a map update or even send them your unit for even more $. see http://www.finedrive-acc.com/shop.cart?action=ITEM&prod_id=F400-08CP
Option two: The other solution was to send it to Fine Digital but they closed their doors in the US so they no longer support us customers. or C&C also offers a repair service for about $150.
Option 3 Because Fine Digtal closed their doors and left us all stranged, I made a DVD with map data I purchased from them before they closed and I added much better instructions; this DVD updates the firmware in the unit and loads the last map data issued to the SD card. you would need a PC with a DVD drive and SD card reader to use it. you can find these DVDs on ebay for $18 which basically covers my costs only. to find it, search ebay for finedrive dvd...
Jan 18, 2009 | Fine Digital FineDrive 400 GPS Receiver
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Oct 07, 2008 | 2007 GMC Acadia SLE
Memory Navi mode
Hi vsudude,
You have to go back to the menu and reset. Youcan take the help of owners mannual supllied along with the unit.
ramesh22
Jun 07, 2008 | Pioneer AVIC-N1 Car DVD Player
Intellinav.exe application error
HELP!! I keep getting Fatal Application Error. Application entellinav.exe has performed an illegal operation and will be shut down. If this problem persists, contact the program vendor. Program: Intellinav.exe
Exception: OxC0000005
Address: 00125D64
Oct 11, 2007 | Nextar Q3 GPS Receiver
GPS Logo
42 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
