Question about Toys
Little tykes trike' we have followed the instructions regarding the hub on the front wheel - pull it out to stop the pedals going round - the hub seems to be loose and did not click into place or anything and the pedals still go round, we do not want to force anything into place and break the hub. any sugestions on where we are going wrong as everything else was easy to assemble. our granddaughter is only 10 months old and we do not need the pedals to be going round
2 Suggested Answers
SOURCE: Just ranover wheel on Little Tykes 3 in 1 Smart Trike
maybe you should look in the mirror when you back up or get a reverse camera from canadian tire
Posted on Aug 07, 2011
Sunny MC-300TKA has a severe front end wobble
Hi, Clemente and the usual suspects are:
1. Improperly loaded motorcycle. Non-standard equipment on the front end such as heavy radio receivers extra lighting equipment or luggage tends to cause unstable handling.
2. Incorrect air suspension pressure.
3. Damaged tires or improper front-rear tire combination.
4. Irregular or peaked front tire tread wear.
5. Incorrect tire pressure.
6. The shock absorber is not functioning normally.
7. Loose wheel axle nuts. Torque to recommended specifications.
8. Excessive wheel hub bearing end play.
9. Improperly vehicle alignment.
10. Steering head bearings improperly adjusted.
11. Tire and wheel unbalanced.
12. Rims and tires are out-of-round or eccentric with the hub.
13. Rims and tires are out-of-true sideways.
14. Loose spokes.
15. Shock absorber improperly adjusted.
16. Worn engine stabilizer links.
17. Damaged rear engine isolation mounts.
18. Swing arm pivot shaft improperly tightened or assembled.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
***** Wobble How To Fix ***** Wobble KevinsOffroad com
http://www.spyderlovers.com/forums/archive/index.php/t-51337.html
Sunny Trike Scooter MC D150TKA Assembly instruction part 3 the end
Sunny TRIKE 300cc
MC D300 TKB Sunny 300cc Roadrunner 3 wheels Trike Motorcycle at...
Sep 24, 2014 | Sunny Motorsports Sunny Powersports...
Can the front wheels be locked
I just Fixed this problem today with the bike Radio Flyer Trike 4 in 1. I just opened the red adjustable hub, and found one spring detached, and both springs that control the 2-pawl system of ratchet system very loose. I tensioned both springs but it worked for one day only. Called customer service, provided all the necessary information and they promised a new front wheel.
In 3 business days a received, a brand new front wheel with pedals and fork. The pedals are fixed on wheel, and is the best solution from radio Flyer for a Kid who is grown with the bike from 18 months to 36 month, and now at age 3 rides the lovely Radio Flyer like a dare devil. Thank you Radio Flyer.
Having a strong mechanical background, I opened system, both sides of the wheel. To dissemble and repair, I had to remove one pedal on the side of the big white hub. What I found inside was a Ratchet wheel, with rounded teeth, and 2 Pawls totally worn out.
I fixed drilling 4 holes all the way through metallic plate, ratchet wheel, and the hub of the wheel. Inside the hub cavity, I used 4 washers and nuts to secure tight all 4, 3/32 stainless steel screws.
My grandson is very happy and more confident, because now he can move the bike forward, and backwards, and the most important, now he can use the pedals of the front wheel to stop the bike. Which it was a safety flaw by original design of this bike, but solved now by Radio Flyer. The new wheel Red Hub has 2 Positions. 1 PULL TO COAST. 2 PUSH TO PEDAL.
Jul 22, 2014 | Radio Flyer Steer and Stroll Deluxe Trike
Radio flyer 4 in 1 trike
Same thing happens today with the bike Radio Flyer Trike 4 in 1. I just opened the red adjustable hub, and found one spring detached, and both springs that control the 2-pawl system of ratchet system very loose. I tensioned both springs but it worked for one day only. Called customer service, provided all the necessary information and they promised a new front wheel.
May 26, 2014 | Radio Flyer Steer and Stroll Deluxe Trike
My sons smart tikes pedals do not move the front tire. The only way to get the bike to move I it is being pushed...? Help please.
Same thing happens today with the bike Radio Flyer Trike 4 in 1. I just opened the red adjustable hub, and found one spring detached, and both springs that control the 2-pawl system of ratchet system very loose. I tensioned both springs but it worked for one day only. Called customer service, provided all the necessary information and they promised a new front wheel. In 3 business days a received, a brand new front wheel with pedals and fork. The pedals are fixed on wheel, and is the best solution from radio Flyer for a Kid who is grown with the bike from 18 months to 36 month, and now at age 3 rides the lovely Radio Flyer like a dare devil. Thank you Radio Flyer.
Nov 29, 2012 | Toys
I just did the same thing.. were you able to get a replacement wheel?
Mar 21, 2010 | Little Tikes Swing Along Castle
Pedals do not always engage the front wheel.
Sep 07, 2009 | Radio Flyer Steer and Stroll Deluxe Trike
I have lost the drive when i pedal.
Hi! No worries about the lingo!
What you are referring to is the free-wheel hub.  This is the rear hub which allows you to have load when you pedal forward, and then move freely when you pedal backwards.
I had a similar experience with a trike and what was needed was to pull the inside of the hub and replace a small spring that looked kind-a like a safety pin.  This is what makes the clicking noise when you pedal backwards or move the bike forward without pedaling.
Not all repair shops are willing to make this repair, and to be honest, I ended up having to go back several times to get the same part repaired, until I gave up and purchased a new hub. If you like to bike a lot and go far, this would be the best course of action.
Jun 16, 2009 | Cycling
Pedals don't turn the front wheel.
You have to take off the tire, pull back the red cap along the pedal post and then pop the white plate off (small flathead screwdriver) to expose the inner hub off the wheel. There is a small metal plate with four screws...maybe the older kids snapped off the screws. You'll need a small flathead screwdriver, pliers or adjustable wrench and regular sized phillips screwdriver.
Jun 05, 2009 | Radio Flyer Steer and Stroll Deluxe Trike
Pedals don't 'engage' the wheels.
Take off the wheel and slide the red metal cap along the pedal post. Pop off the white plate with a small flathead screwdriver. This will expose the inner hub of the wheel. There should be a small metal plate held to the hub of the wheel with four screws...check the screws...did they snap off? You can also call the Radio Flyer customer service line (8-5) and get some help if you need a new wheel.
Apr 07, 2009 | Radio Flyer Steer and Stroll Deluxe Trike
Kettler Air Navigator Tricycle
My husband and I just put this trike together and had a similar problem - the front wheel always turned the pedals and we couldn't figure out how to stop this. The manual for the trike is awful and very hard to understand. After spending a LOT of time analyzing the pictures and doing all sorts of weird things to the pedals, I found a posting on a website that said they'd had the same problem, but had removed and re-attached the front wheel and the problem was suddenly fixed. Sounds too good to be true, right? Well, we noticed that in one of the manual's pictures that the air valve for the front tire was facing the other direction - we'd actually put the tire on backwards. I took the tire off, put it back on facing the other way, and suddenly it all works as it's supposed to.
The thing is, you actually don't have to "do" anything to change from free to fixed and keep the pedals stable. If my daughter pushes the pedals around, they move around, and if she keeps her feet steady on them, the wheel continues to go around while the pedals stay put. It truly is automatic, which the diagram in the manual does a terrible job of conveying.
Hope this helps someone. We like this trike, but the directions are beastly!
Aug 18, 2008 | Kettler Kiddi-o Supreme Stroller Trike
Toys Logo
55 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
