Question about Neff 24 in. S5443X2 Built-in Dishwasher
Hi, we have a Neff dishwasher and noticed a couple of days ago that it took hours longer than usual for the dishwasher to complete its cycle. Last night after the machine had been on for about 4 hours we checked and although there was some water at the bottom of the machine it had not started to wash the dishes although we had heard noises coming from the machine. On opening the integrated door notice that the "check water supply" indicator was lit up. Do you have any suggestions as to what we should do? We have had a look in the manual but it does not give much info do you have any practical advice please.
murdozzz2
  • 75 Answers
SOURCE: Neff slimline dishwasher type S5946
hi there sounds like your wash pump has burnt out
Posted on Jan 11, 2008
SOURCE: neff integrated dishwasher
there are some screws inside the door, around the edge. These would be the first to undo then I think the door would have o be pulled up slightly to relaease.
Posted on May 05, 2008
SOURCE: adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Posted on Aug 17, 2008
SOURCE: loud bang and fusing dishwasher
chucked it !!
Posted on Nov 16, 2008
SOURCE: Neff dishwasher removal
Hi when you open the door there are two hole about a therd of the way down each side you will be able to see the screw head undo these then pull door up. it will come off quite quickly so becareful.
Tony
Posted on Mar 28, 2009
Takes dishwasher hours to complete cycle
How long did it usually take to finish? Do you know which part of the cycle is taking a long time? Like when it starts when you hear it running. How long have you owned the unit? Once I have more information I can assist you further.
Thanks,
Lee
Oct 22, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Neff dishwasher - bottom tray not cleaning - rotary arm not turning
If your dishwasher is 10 years old and you are facing a significant repair cost, it may be time to consider replacement.
Jan 01, 2014 | Neff Dishwashers
Dishwasher door will not close properly
usually d/w doors are fine for long time.
1. check if anything blocks it to close securely e.g. the cutlery basket or the dish racks not fully sliding in or may be off track/chanel.
2. try running a cycle empty and see if it closes after doing #1.
Jul 25, 2013 | Neff S51M53X0 24 in. Built-in Dishwasher
I've had my dishwasher (GU2455XTSB3) for almost 2 years. The first year and half were great. I always use the same cycle (with options) and it took approximately 1.5 hours to complete. Now it takes over 3...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Oct 23, 2010 | Whirlpool GU2455XTS Built-in Dishwasher
I have a neff dishwasher that is maybe 5 years old. im pretty sure there is nothing wrong with it as it was working perfectly fine before i had a plumbing problem a few days ago. after the plumbing problem...
Look for the connection from the valve to the inlet of diswasher. Check the hot water valve to be on. It is probably closed when anyone working on the plumping. Good luck.
Jul 05, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Neff Dishwasher
The offending parts are on the left hand side of the machine (viewed from the front). You need to remove a screw (or two?) at the back top edge of the side panel which will then lift upwards and come off.
Before I did my fixit I phoned Neff service (actually BSH appliance care) who quoted me £60.50 for the first half hour then £45/hour plus parts or £159 for 12 months parts and labour. A bit of a no brainer! Anyway, I provisionally booked a service call but said I would call back to confirm.
2 days later I still had the machine pulled out and the panel off because I was testing it. Phone rings - service engineer to say he's on his way. Thought he may as well look at it anyway. He said I'd done exactly what he would have done except he'd have used new part instead of cleaning out the original. He even cancelled the call off his system so no call out charge!! He also told me that 1 minute on the timer display is actually an error code not the actual time left.
Be warned - after the fix I ran the machine on a rinse cycle - completed ok. Put it on an auto wash cycle and it stuck with 1 minute to go! Much swearing and cursing!!
However all subsequent washes have been fine and it has now been working properly for several weeks.
I took some photos whilst I was doing the repair - I can email them to you if you want.
Hope the above makes sense - good luck.
Sep 30, 2008 | Dishwashers
Neff washing machine W5320
What is the temp of the water coming in to the unit. If it is not hot enough some machines heat the water up to a prescribed temp before washing, rinsing etc..... Could be a problem with the sensor too...let me know,
Feb 10, 2008 | Neff W5340X0 Washer
NEFF S5456 DISHWASHER
Have you tried it on a different program? I have nearly always used the AUTO program - however i have used the 50 degree program 3 times now and it completes the (much longer) wash without sticking on one minute. Will try it on auto again to see what happens. I found it useful to turn the end-of-wash buzzer on (to loud) to remind me when (if) it completes the program.
Sep 30, 2007 | Neff 24 in. S5456 Built-in Dishwasher
Maytag Dishwasher Model: MDBTT59AW
My research indicates that this is a control board malfunction, but with so many different descriptions of failure, I am left confused.
You may reference the link below to help isolate your problem.
http://www.repairclinic.com/0088_9_1.asp#Level1_9
Sep 07, 2007 | Maytag 24 in. DWU9202 Built-in Dishwasher
Neff 24 in. S5443X2 Built-in Dishwasher Logo
56 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
