Question about Garden
It doesn't recharge the player battery doesn't show that the player charge statuse doesn't show any change please help me to solve this problem
  • 17,130 Answers
You have not stated the make/model of the set in question but please make sure that the charging adapter or the circuit is supplying enough charging current to the battery .
So use a multimeter and check the voltage when the charging takes places, check the battery voltage, if there is no charging voltage or the current ( if you use a series test in high range) then the adapter is faulty. If charging voltage and current is present with no charge retaining then the battery is faulty.
Posted on Mar 26, 2011
Why doesn't my hp notebook charge?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 08, 2013 | HP Pavilion Computers & Internet
Samsung gt e3213k charging problem.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 07, 2012 | Samsung Cell Phones
Lens won't close and On/Off button doesn't work
Even though the battery appears to be charging it may be shot. Some batteries if they run down too far can not be recharged. You need to try a new battery in the camera.
Jul 25, 2012 | Nikon COOLPIX S6000 Digital Camera
My latte espresso battery keeps dying to fast when it's an 8gb and suppose 2 last for 6-7hrs but it only lasts about 3mins can somebody please tell me what to do!!!!!!!!!!!!!
Ifthe rechargeable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 01, 2011 | Bell Technology Latte Communications Ice ...
Unable to charge the MP3 player. I pluug it into the computer but it doesn,t charge.
The ilo 2GB mp3 only uses AAA batteries and will not recharge them. It is not designed to recharge the battery.
Nov 27, 2009 | iLO (2 GB) MP3 Player
Dvd player recharger charge status lights blink
The blinking went away as I had charged it for a very long time. However, it was noted that it would not work on the DVD. The battery needs to be replaced. That solved my problem. I still have to look for a new battery for this device: US Logic 680p DVD player with recharging capabilities due to the portability option. It works fine if plugged in, but the battery just needs to be replaced if I want to use it independent of the plug. Thanks for asking how I resolved the issue.
Nov 25, 2008 | US Logic 680P Portable DVD Player with...
Printer will not charge camera batteries. camera screen said to go on line and look for m627-435
Did you go online and look up this troubleshooting tip from HP?  Did you make sure the batteries are rechargeable and in the correct orientation ( + and - )? Here is the results from looking up the error code M627-435 at the HP website:
Solution
  1. Ensure that the batteries are rechargeable. If the batteries are not rechargeable, replace them with rechargeable batteries.
  2. If the batteries are rechargeable, take them out and check for obvious physical damage. If the batteries are damaged, replace the batteries with rechargeable batteries in good physical condition.
  3. If the batteries are in good condition, charge the batteries using the external charger that shipped with the camera before using them in the camera for the first time.
  4. If you have tried each of the steps above and the status message still displays when you try to charge the batteries, replace the batteries.
Cause The Batteries cannot be charged status message is usually caused by one of the following:
  • When first connected to an optional HP AC power adapter or placed on an optional dock, the camera performs a test to determine if the batteries are rechargeable. If the test determines that the batteries are non-rechargeable, an status message displays in the LCD.
  • If the battery charge falls below 1.1 volts, the camera cannot detect that the batteries are rechargeable. The camera does not charge batteries below a 1.1-volt threshold to prevent charging non-rechargeable batteries. Rechargeable batteries discharged below 1.1 volts can be charged in an external charger.
    Apparently, your batteries are either seriously discharged where you need to use an external AC charger to recharge the batteries or their damagaed and need replacing. Hope this helps.
Oct 31, 2008 | HP Cameras
RECHARGABLE BATYERY DOESN´T CHARGE
you probably will have to go and buy a whole new one. theses kind of batteries only last about 1 year.
Oct 21, 2008 | Durabrand PDV-709
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
