Question about Toshiba Satellite A135-S2386 Notebook
Touch pad is on fire!
After about 20 minutes, the touch pad...think that's what the name of it is, is seriously buring my fingers up. It's abnormally hot! What's the problem?
  • focal Aug 16, 2008
    same laptop... battery pack is PA3465U-1BRS just today, regular mouse stopped working tried the touchpad - works... 1 minute later try the touchpad ... doesn't work. Figured I would restart it and that would be that.... well turned it off but doesn't come back on! just blank black screen, thats whe I noticed how hot (very) the touchpad was, the bottom side of the laptop was also very hot..
    thanks you guys in advance for the help }:-)
    Peace
Same laptop but intel core 2 duo, and I got the same problem , my touch pad is very hot sometime and I have the cooling fan underneath the laptop it's help! and after that like couple weeks later my laptop was death it wasn't boot the vista. it shown the options like 1. fix the ..... 2. start normally.
when I choose No.1, the screen turn BLANK all day and nothing changed and I power shut down and choose No.2, then it boot!! But the programs were not boot well and stuck like not completed. SO what's wrong with it???
Posted on Aug 29, 2008
  • peapepzi Aug 29, 2008
    Opp!! it's works when I plugged the battery. and it's runs good.
  • peapepzi Apr 10, 2009
    Before when I had the anti-spyware and I leave the laptop till it turn into save mode, It was death(never turn back) . But You know what!! now my laptop is runs very good. After I buy the Cooling fan, Dustoff(sometime it needs to clean) and uninstall the anti-spyware. It NO PROBLEM any more. I can leave it run 20 hrs a day fine.
    Ps. It need to plugg in battery all time too.
How to perform scroll function in laptop without mouse in Dell vostro
Your touch pad should do the trick.
They are called "Gestures". They are set to active by default. If it's not. Go to "Control panel > click "mouse" and find "touch pad". There you will find "Gestures". Activate it.
1. Put two fingers on the touch pad and try to move both fingers up or down. Learn how to scroll up and down.
2. Move those fingers side ways. This should do the "Horizontal" scroll.
There are others, like:
Put one finger stationary and rotate the other. This rotates the orientation of the object.
Try it and good luck.
May 23, 2014 | Dell Vostro 1510 Laptop
How to used the touch pad
Use the touch pad to move the pointer around the screen.
Run your finger over the touch pad in the direction you want the pointer to move and then click the left touch bar (this works as the left button on a mouse).
Apr 16, 2012 | Computers & Internet
When I am using the internet to send emails sometimes when I move the cursor using the touch pad the text size ruduces and I can't get the size back to what it was
Its a special feature of laptops' touch pad that if u slide two finger(one horizontal and one vertical) simontaneously, it will zoom in or out... Try not to touch two fingers simontaneously on touch pad.... It also occurs with me... Thanks..
Feb 21, 2011 | Computers & Internet
What is the internal touch pad?
internal touch pad is the touch pad where you put your finger to roll over your cursor instead of using an external mouse. External touch pad is also called external mouse.
Oct 13, 2010 | Acer Aspire 5500 5570-2609 Laptop
HOW TO CHANGE THE TIME ON A Technika CR-109IP
1)touch and hold both the M and E touch pads for at least 1 second to enter clock setting mode
2)set the hour by touching either of the the arrow touch pads on the top panel to increase or decrease the number
3)when the hour is set correctly touch the E touch pad to confirm
4)the minute digit will now flash. set the minutes by touching either arrow touch pad on the top panel to increase or decrease the minutes
5) when the minutes are set correctly touch the E touch pad to confirm
the clock is now set
Sep 19, 2010 | Audio Players & Recorders
I HAVE A MAYTAG BUILT IN OVEN THAT WAS WORKING FINE LAST NIGHT AND GET UP THIS MORNING TO BAKE AND I AM GETTING, ITS FLASHING A F2 AND F7 ERROR CODE AND THE ALARM OR BEEPING IS GOING OFF
Hi You have a bad touch pad , there maybe a be a button stuck in , try running your fingers over all the touch buttons but i think the touch pad will need to be replaced as always remove the power before taking it a part
Dec 21, 2009 | Maytag CWE4800A Electric Single Oven
Where are the brake sensors located?
Sensors in this vehicle pertain to the wear sensor on the front brake pad.It is a protruding metal finger on the pad itself, which will produce a "metal to metal" high pitched "scraping" squeel once pad wear permits this finger to touch.This worns you there is a minimal amount of pad thickness remaining and approaching a serious "metal to metal" condition which will wipe out rotors and more.
Aug 22, 2009 | 1995 Buick LeSabre
Pointer jumps around on screen when touching touch pad
hello, have you tryed adjusting the sensitivity of the touch pad to a less sensitive touch ?
Mar 31, 2009 | Acer Aspire 5610 Notebook
System freezing when touchpad not being used.
This will be one of three things; 1- a driver glitch with the touch pad. Uninstall the drivers for the touch pad from the device manager, then reboot. The machine will find the touch pad and reinstall the drivers automatically. You might also look at Compaq's support site for any updated drivers or patches for the touch pad. 2- You may have a loose connection. Remove the keyboard, check and clean the touch pad connection/connector. 3- A faulty touch pad. If the other two don't work, then disconnect the touch pad and try using the machine with an external mouse. If this works, then the touch pad has malfunctioned and needs replacing. Ty these and let me know.
Aug 01, 2008 | Compaq Presario V4000 Notebook
Toshiba Satellite A135-S2386 Notebook Logo
61 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
