I have got a dell inspiron laptop..bought just two months back.. when ever i start my laptop an alert message pops up 'Hard disk problem is preventing the windows to start '.
    Scholar:
  • 93 Answers
If the computer is under warranty then contact the dealer -manufacturer first-
If not you can use another computer to download a program called sea-tools - burn this to a cd disc - start your computer then go into set-up-usually by holding delete button or some times f2 change your start up boot sequence so your c/d -dvd rom boots first --insert the cd into your cd drive then restart the computer --once the computer boots from the cd follow the prompts from the sea tools program it will run a couple of checks and give you a hard drive report it will also attempt to repair your drive it it can .
I hope this helps
Andrew
Posted on Mar 26, 2011
Dell inspiron 700m break the password
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-700m-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Dec 01, 2011 | Dell Inspiron 700M Notebook
What's your problem?when starting up my laptop, I get the error message 'device in module bay not recognised or not connected
If you dont get into Windows this probably means that your hard drive is crashed. Just try to plug off the hard disk after switching the laptop off by un screwing the cap at the bottom of the laptop, unscrewing any screws that hold the hard disk and gently unplug the disk. Test againwithout the disk if you get the same alert, if so then its mostly the hard disk failure.
Sep 18, 2011 | Dell Computers & Internet
I have dell inspiron 1525, with windows 7, and this message appear whenever trying to login to my pc.. "Windows failed to start, a recent hardware or software change might be the cause. File:...
The hard drive may had a BAD SECTOR ( corrupt section )
try to format with normal mode,NOT quick format.
try using LLFTOOL ( hard disk low level format ) http://hddguru.com
quite bit longer to fix the bad section,but works.
akee.4shared.com
Aug 15, 2011 | Dell Inspiron 1525 Laptop
I had just purchased a Dell Inspiron N4010 laptop 2 months ago. It work well until few days ago. It hangs whilst at the screen 'starting windows'. After that it showed the message of 'check cable...
hello miss sally, hi, the operating system error may be caused by a faulty hard disk or hard disk connection cable, and the hanging thing is caused by a faulty memory module, so check then out first, swap a new memory module, and for your hard drive, take it out from your laptop and use a PC to test the drive (applicable only if your hard drive is sata.)
Nov 19, 2010 | Dell Computers & Internet
I have a Dell Inspiron 1545 notebook. I just bought it less than a month ago. When I power down it will not start up. It goes to the dell logo page and freezes. Why??????
At less than 1 month old, this is a potential warranty call. Installing questionably safe software could have caused this problem too.
If you haven't had it long enough to accumulate a great amount of valuable data on the hard drive, you could simply try to do a factory restore with the restore disks that shipped with the computer or by holding down a key at start-up to launch a built in restore program. (the key options should be displayed on your screen during start-up)
Mar 17, 2010 | Dell Inspiron 1545 Notebook
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
Can't get my 1525 inspiron to start up, error message 0146
Error Message 0146 is a hard disk drive failure. Replace the hard drive.
Jan 21, 2010 | Dell Inspiron 1525 Laptop
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
Inspiron 6000 HDD relacement problem
please contact dell support on 18006249896 coz it could also be a problem with the MB
Dec 28, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
David Payne
David Payne
