When i start my cpu, cpu is working but not showing anything in the computer.
  • 17,130 Answers
Unless there is any display to indicate the doubts are on the sections of the processor and the display drivers.
You need to check on the main board in the section of the display drivers and interface.
Posted on Mar 26, 2011
Monitor keeps shuting down
what do you mean by "computer starts"????? plz write full detail. first remove your monitor cable from your cpu cabinet. if you are able to see "no signal" message on screen then your monitor is working. if you aren't seeing anything on your screen then there is some problem with your monitor. there also may be problem with your VGA connection (VGA or D-Sub wire). remove and reconnect this wire from both end. first reconnect it from your monitor and then from your video card. if it dosen't fix then you have to check that all led's are glowing on your cpu cabinet or not. if only power led is glowing and other led's always remains off, then there may be problem with your video card or ram or hdd. first open your pc case, then if you have video card, then remove it and put it again. reconnect your hdd sata wire. remove your ram and place it again. if now also not showing anything on your screen, then there is problem with your motherboard bios.
Apr 10, 2013 | Computers & Internet
I got a Compaq Presario SR1903wm .with red blinking light !!! power's up for about 20 seconds then shuts off !! doesnt even start up in Bios !! Dont know what to do !! should i replace the power supply...
check the ram memory ..if this shows up OK (verify it in another computer with the same specifications ) ...than the CPU is to blame ..open it up ..and remove for a few seconds the Bios battery to see if you messed up with the temperature settings ..This will reset to factory settings ..and if there is teh case with temperature limits too low set ..than it will power up after ..if it is the CPU you will have to change it
Jan 28, 2011 | Compaq Presario 5000 PC Desktop
CPU will not reboot
computer not starting up,theres a bios reset button,try that,does the monitor show anything atall,if not check cable to monitor
Jul 05, 2010 | Siemens Simatic S5 HMI Monitor
The cpu would not come on
no if the computer starts up but doesn't post but everything else turns on then there could be a problem with (a) the drive is not hooked correctly (b) drive drive is not pluged in (c) the drive is not working (d) motherboard is damaged from electrical spike
Jan 25, 2010 | Computers & Internet
Installing a new cpu? WHAT HAPPENS
hey, if u changed ur cpu it never make any change it will directly loged to os, and it also occurs in change of graphic card also, some graphic cards shows the graphic card BIOS(info) b4 ur mobo bios....
Jan 14, 2010 | EPoX EP-8KRA2+ Motherboard
My hansol 700Fs silver just blacked out one day. it shows no sign of life even with the mains connected. is there a fuse in there somewhere, or is it just dead?
Try remove the video cable from the CPU, if there's a sign of anything(warning,etc), try it in another CPU, this should works.
And the problems is in Video Card from the CPU.Try replace this Video Card.
Dec 08, 2009 | Hansol 700 FS 17" LCD Monitor
Just upgraded VGA card to GeForce 9800GT. Now LG
Sounds like your Video card is not installed properly, you should take it out and then put it back securely into the motherboard. If its installed properly the monitor should come on during the start up screen at least to show the type of video card installed.
Also let me ask what model was your old Video card?
Mar 20, 2009 | LG L1915S 19" LCD Monitor
My comp does not show anything on the moniter??
If you have another monitor try it, if it works then you have a bad monitor. If a different monitor doesn't work in it then it could be the motherboard or CPU. If they are bad there is not test for that, the only real way to test them is to buy one piece at a time and see which one works. Also if your monitor has a power adapter check it. Sometimes those do die and not the monitor.
Feb 26, 2009 | HP Pavilion (PN153AAR) PC Desktop
Analog Monitor problem
The problem in your monitor is SRGB
Use 3 simple steps to rectify this problem
1. Connect your monitor to another CPU
2. Change The Resolution to 800x600 32/24bit
(After 2 Miniuts SRGB will Reset)
3. After 5 Miniuts change the monitor to your CPU
Thank U
Apr 06, 2008 | Computers & Internet
Screen not showing anything
Some time the system will work due to insufficient power source this problem may occur replace SMPS and check the CPU heat by touching it. If it warm then the CPU is functioning. Else contact your nearest hardware vendor.
Hope this will solve your problem.
Nov 22, 2007 | Asrock GE PRO-M2 Motherboard
Computers & Internet Logo
32 people viewed this question
Alun Cox
David Payne
David Payne
