Question about E-Machines Computers & Internet
I don't know how to open the CD/ DVD so I can place it in the player and then how to eject the CD/ DVD , when finished? Can you help me please? Emachine EL1333 Athlon
  • 26 Answers
OPEN MY COMPUTER AND CLICK EJECT ON THE DRIVE IN QUESTION IF THAT DOES NOT OPEN THE DIRVE THEN FIND A PAPER CLIP AND PLACE IT IN THE DRIVE DOOR HOLE AND MANUALLY OPEN THE DRIVE BEST OF LUCK
Posted on Mar 26, 2011
Philips DVD recorder, (250gb) DVDR3460H. can not remove disk .........
your gonna have to open the machine up the there is a whits tab that lifts the disc up to spin you will have to use your fingers to slde it of that make sure its unplugged and then the white thing will realese
Sep 19, 2008 | Televison & Video
Wont eject my cd
Try pressing repeatedly the eject button while you turn on the unit. If it does not work
then it is a mechanically problem in your player.You need to be manually open to take out the dvd.
The rubber thread which should be connected to the motor inside the DVD player might have moved from its place.You need to place the rubber thread to proper place.
Hope this helps.
Shane
Feb 11, 2011 | JVC KD-G200 CD Player
How to play a cd
Usually the DVD drive or the CD drive has a very small button on the front side of the Drive, if you see a button press it, the tray will come out and you will be able to put the cd on the tray and than press that button again it will take the cd in and will play for you.
However if you feel that difficult, try doing this,
simply go to MY COMPUTER, there you can see your dvd-drive or cd-drive, you can right click on the drive and click on "eject" it will eject the tray just like a normal dvd or cd player and you can insert the disc to play.
if there is anything else i can help you with please let me know.
Thank you.
May 18, 2010 | E-Machines eMachines Desktop PC
I am unable to eject a DVD disk from the player either with the remote or player mounted buttons. Your advice would be appreciated.
do this with the unit off:1Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
Step2Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It’s the part that holds the DVD loader in place. Step3Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases. Step4Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn’t quite finished yet. Step5Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center. Step6Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you’re careful. You should be able to access and remove the disc.
if this helps dont forget to leave a fixya rating as thats how we get paid
Apr 25, 2009 | Toshiba SD-K220S DVD/CD Player w/Built-in...
Philips DVP-3020K not eject my CD
hello my friend! my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Dec 21, 2008 | Philips DVP-3005 DVD Player
DAV DZ100 - Not working
2 options comes in my mind...
Put software upgrading CD manually in player and let it finish software upgrade process.
If this trick doesn't work, you need to replace digital process board or need to replace on board ROM, if you can.
let me know if you need further info.
Oct 25, 2008 | Sony DAV-DZ100 System
Panasonic stereo with 5-cd changer
Hi, I have a Panasonic SA-ak25 system. I played one cd then inserted a second. When the second cd had finished it ejected but the first cd is still in the player, When i try to eject it the lights start to flash and it always stops on no (4) can anybody help. Bob.
Jun 15, 2008 | Audio Players & Recorders
Two dvd's stuck in player
you cant get the system to open until repairing it but to get ur cds open ur system and take apart the place where the disc sets to start playing the movie
Dec 21, 2007 | RCA DRC8300N DVD Recorder/VCR
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
