Question about GPS
Nissan Radio / cd player (require installation kit) B81858M800 wiring diagram for this radio to install in the car.
  • 1623 Answers
SOURCE: I have a 96 honda
just buy an iso plug from ebay to connect it, no cutting of wires or rewiring just plug into the existing wiring in the car and then buy an iso plug for the stereo
Posted on Apr 13, 2011
mixmaster
  • 626 Answers
SOURCE: radio wiring diagram
THis site has most other Mitsubishi Vehicles.
I have not seen yours listed on there, but generally the wring diagrams are the same across the models.
http://www.the12volt.com/installbay/vehiclewiring/1/yeard/Mitsubishi.html
Best of Luck.
Posted on Nov 04, 2007
edwardjwoods
  • 372 Answers
SOURCE: radio wiring color codes
u need the colors of the radio or the car wires.... here are the car wires and the radio are below that. I suggest however gettiing a wiring kit..They are around 8 dollars and well worth the money. It makes is so easy to connect a radio.
RADIO 12V|orange + at radio
RADIO GROUND Black
RADIO SWITCH yellow
POWER ANTENNA dk. green at radio LF SPEAKER tan - gray at radio or LF speaker
RF SPEAKER lt. grn - dk. grn at radio or RF speaker LR SPEAKER brown - yellow at radio or LR speaker
RR SPEAKER dk. blu - lt. blu at radio or RR speaker
Radio wiring
constant power yellow
switched power red
power antenna/amp turn on blue
illumination is orange
all speakers the one with the black stripe is the negative connection.
right rear is purple
left rear is green
left front is white
right front is grey
hope that helps ya...
Posted on Sep 02, 2008
alicantecoli
  • 22326 Answers
SOURCE: 2004 Volkswagen Beetle Radio/CD player
new one with a usb connector and sd card reader is better and cheaper
Posted on Jan 31, 2009
SOURCE: wiring diagram for car radio
WHERE DO I CONNECT THE PINK WIRE IN THE JENSEN VM9311TS AM/FM/DVD/MP3 RECEIVER
Posted on Apr 14, 2009
What kind of adapter to install cd player into 2000 malibu
what you will need is the radio adapter kit for your car make. also you need a wiring connector for the car between car wiring and radio. match the wires to wires on radio, and then the connector will fit car wiring connector, just plug it in to car wiring.
May 07, 2010 | Corvette Chevy Malibu 90-04 Car Radio...
Radio installation
1985 Chevrolet S10 Pickup Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 4′ x 10′
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 08, 2009 | 1988 Chevrolet S-10
Wiring difference
If your installing a stock radio/cd player from another Dodge the wiring plug is the same and will fit.If your installing a aftermarket radio/cd player(JVC,Pioneer,etc)you will need to buy a adapter plug that wires up to the radio and is a direct fit to your factory wire harness,so your not cutting your wires.When you buy the adapter plug it comes with a wire diagram of which wire is what.Your aftermarket radio should have a diagram also,either on it or in the manual.Hope this helps you.
Mar 04, 2009 | 2002 Dodge Caravan
Want to replace factory radio
go to walmart find your cd player, dash kit ,wiring kit and then this is what you do .. remove the old radio attach the wiring harnes you bought to the factory wiring harnes this will allow you to match the color code up for your new radio with out cuting wires then install the new dash kit witch will allow you to install your cd player with a factory look this should be everything ou need to know
Dec 04, 2008 | 1995 Oldsmobile Eighty Eight
Need wiring schematic for radio
Are you looking for the wiring diagram for the car or the cd player itself? If you have the wiring diagram for the CD player, and a test light, you can easily install with out the car wiring diagram. If you require more assistance please let me know.
Nov 28, 2008 | 2002 Buick Park Avenue
Replace 2005 Nissan altima stereo receiver
Try radio shack, or stereo sales/installation place for ready to go plug adapter. For a few bucks, it saves headaches, and butchering the wiring in case you want to re-install old one later when trading in or selling the car.
Aug 30, 2008 | 2005 Nissan Altima
Need to know color schematics for radio harness wiring
If installing Toyota radios/CD Players they just plug in regluar sockets in vehicle.
If installing Non-Toyota radios/CD Players youll have to buy a wiring kit from Wal-Mart/Circuit City/etc it would have the wiring diagram in it.
Jul 27, 2008 | 2003 Toyota ECHO
Wiring diagram
First, goto a store and buy a snap in wire harness and a mounting kit. There are wire diagrams in the packaging. Wire your wire harness into the radios wire harness (everything is color coded). Follow the intructions to install the mounting kit. It should tell you what screws to remove from your dash and so forth. Just remeber were everything goes. Next, after you remove the old radio, snap in you wire harness to the cars wire harness. Then, test the radio to see if it powers up and all speakers are working. Lastly, put you radio in your dash, and put everything back togeather. The number one rule in installation is take your time. If you rush, you will brake something.
Jun 02, 2008 | Pioneer DEH-P2000 CD Player
Installation
i suggest getting a wire harnees kit from an auto supply shop{pep boys,autozone,)the wire are usually color coded.also try going to to clarions support site they probably have a diagram 4 u.if not get back to me and ill tell you how to test and discorer what wire is what.if you connect wrong wire you can burn out your radio
Jan 21, 2008 | Clarion DXZ945MP CD Player
GPS Logo
227 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
