Question about AEG Washing Machines
Hi, I have problems with my washing machine.While I was washing my clothes code EF0 appeared and now its not working, its just making a noise even when it is in OFF mode. Machine model is AEG EXCLUSIVE OKO LAVAMAT 73739. Please help if you have any idea what to do about that. Thank you.
    Brigadier General:
  • 6,277 Answers
I do not have EF0 in the list of error codes for AEG's but EF1 for some models is a blocked drain pump.
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 26, 2011
Why my kenmore front loader is showing EF0?
I cannot see a EF0 Code for that Machine,
Info fact take a look at this error code sheets for all errors for your machine.
http://www.applianceblog.com/mainforums/threads/10283-He2-Error-Codes and look at the PDF file, on where you can download all the codes to help.
Sorry could not help more
--N
May 15, 2014 | Kenmore HE2 Plus Front Load Washer
Mashine make noise and vibrating a lot
Hi, your washing machine makes noises because all the clothes and other materials are not balanced evenly--one side is heavier than the other--causing the drum to hit the sides of the washer wall.
Sep 29, 2010 | Ariston Technologies Ariston AWD12 Front...
Makes a loud banging noise as if the load is underbalanced even through the load is balanced.
HI There
Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Let me know how this goes and thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Kenmore Washing Machines
Hotpoint VBSR2080WOWW washing machine vibrates with loud noise
hi,
this is a generic problem with top-loading washing machines. when the distribution of load is not uniform, it gives sound when spinning. if it produces noise even after equal distribution of clothes, the problem lies in the suspension. this is not a major fault, and can be put up with, rather than spending dollars on fixing it. this will in no way cause any special wear and tear for the machine.
cheers
Jul 22, 2009 | Hotpoint VBSR3100D Top Load Washer
Not hot water EF0 code
Check for kinked or blocked
incoming water hoses, clean the incoming
water screens. If problem still remains,
replace the water inlet valve assembly
May 16, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Error code EFO or EF0 I can't tell the difference.
You need to refer to the owners manual in trouble shooting catagory, if you can't find yur answer there contact Fridgadaire ither by phone or e-mail and choose the help section.
Jan 05, 2009 | Frigidaire ATF6000ES Front Load Washer
How do I reset the EFO Aqua Control system?
Thanks Guest! It worked perfectly lifting the face of your machine by 45 degrees
The washing machine was full of powder (this was the cause)
Aug 16, 2008 | AEG Lavamat 88840 Front Load Washer
Washing machine
it could be the break above the transmission. it engages what looks like break shoes when the machine is not spinning. if these are worn down to the rivets then it will make this noise. it requires a special tool to replace.0de7df9.jpg
Jul 14, 2008 | Kenmore 23822 Top Load Washer
Whirlpool washer makes loud noise but aggitator doesn't even turn
a load of Jeans or pants is hardest on washing machines , you probably broke the belt for the aggitator
Dec 14, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
365 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
