Question about Refrigerators
I have a new Hitachi fridge, since day one the food inside the fridge has a taste of fridge.
    Scholar:
  • 116 Answers
Hi, try some baking soda, and you may want to seal up your food.
Sean
Posted on Mar 26, 2011
Fridge smell and taste makes you sick, very clean and no food in it
Keep it open for a 4 or 5 hours... Then keep some cut lemon inside it.
Oct 27, 2012 | Hotpoint HSS25GFP Side by Side...
Chemical cleaner taste in water and ice from fridge door.
Run it as normal and keep flushing the water through. Place lemon wedges around the inside for the next week. If the problem persists you can buy a proprietory air conditioning system cleaner for cars that disperses inside the unit (make sure no food is left in while using) follow makers instructions. Clean with low pressure hot water spray before using again.
Apr 20, 2012 | Kenmore Refrigerators
Samsung RF267 water tastes terrible. Filters changed twice and not helping
If new plumbing, system is flushing and may cause a bad taste or odd color.Has a food item spoiled?
Make sure that strong smelling food (for example, fish) is wrapped so that it
is airtight.
Clean out your freezer periodically and throw away any spoiled or suspect food. Place foods in airtight containers to prevent the transfer of odors.And also Flush out water hose from tap end to freezer with warm water And also clean fridge with wet cloth (with soap solution). And then clean with dry cloth. .Keep fridge door open after cleaning all compartments for 4hrs minimum, as fresh air could wipe out any bad odor in fridge. And then start using fridge. Hope, it's helpful.
Jan 29, 2011 | Samsung RM255LASH Side by Side...
Our new Samsung fridge has horrible tasting water
add water filter system to the unit ..
if it is not the water from the unit that bad then filter change might need to be done...or a new filter need to put inside.
Dec 30, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator and freezer musty, freezer burned smell? ?
they should be washed every2 months use baking soda and a box of fridge charcoal
thumbs up
Aug 17, 2009 | Frigidaire GLRS264ZA Side by Side...
Ice maker water taste like chlorine but tap tastes fine
Put a in-line water filter on the water line if you want. The taste is from the food and items you have in the refrigerator. Clean it out and keep your items in proper storage. Ice collects the smells in the line and the fridge. Change your ice that is sitting in the bin, wask out the bin with water and baking soda. Hope this helps.
Apr 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Fridge has chemical smell
The smells are being pulled in through the air intake from the fridge from the chemicals they used on the floor. As the coating cures, the odor will end. As for the damage to your food and drinks? I would assume if the food tastes like the chemicals, I would avoid eatting them if you do not like the taste )
Apr 06, 2009 | Hotpoint HSS25GFP Side by Side...
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge smells
Are there any drip channels in the back or bottom of the interior of the unit that may be clogged? These channels collect condensate and feed them to a pan under most refrigerators. I assume you have removed bottom food storage drawers and cleaned inside. Also try open box of baking soda which absorbs odors.
Feb 26, 2008 | Refrigerators
Smelly Fridge
Try putting an open can or two of coffee inside. My mother's freezer had gotten unpluged and it was full of fish. She put cans of coffee inside and shut the door a couple of days later she took them out and the freezer did not stink anymore. Hope it works for you.
May 05, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
