Computer is dead, can the motherboard be replaced reasonably or should just get a new computer???
  • 32,281 Answers
You can replace the motherboard. The desktop have standard mounting hole and motherboard manufacturers have used these standard mountings.
There are a large range of motherboards from different manufacturers. Make sure the existing power supply is adequate for the new motherboard and components.
Posted on Mar 26, 2011
I have a Philips Freevents X57 Laptop which has a motherboard problem. When I switch the laptop "ON" these are the following symtoms: A) Power Charger in AC/DC Socket without battery: Power...
Possibilities:
* leaking/bad capacitors on the motherboard, not doing their job, i.e., causing voltage fluctuations that the motherboard cannot tolerate;
* dead disk-drive -- cannot boot Windows from a "dead" drive;
* dead CPU -- cannot do anything other than power on/off;
* failing power-supply -- not supplying correct voltages to the motherboard.
Take the laptop to a qualified computer technician, for professional trouble-shooting, and probably a replacement of the motherboard. But, it might be less expensive to "salvage" the disk-drive (and your files) from the laptop, and to buy a new laptop, than it would be to buy a replacement motherboard, and pay for installation.
May 20, 2011 | Philips (142440) Computer Speakers
Hi Swithced my pc on and have no display. couple of days ago pc switched off by itself. New powersupply installed but problem still persists. please advise Regards A
It sounds to me that your computer mainboard is faulty.
I have created a published guide entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Note the section on clearing the BIOS/CMOS.
You could try replacing the silver 3V battery on your computer mainboard.
I think it may be a dead capacitor some-where on your computer mainboard, some technicians will replace it for you.
Thumbs up!
damnor01
Jan 16, 2011 | MSI 915G Combo-FR Motherboard
I recently bought a Maxidata msi 865GM3-LS (ms - 7037 Ver:1) Motherboard. However after two days of use it went down. Since then I've not managed to boot form the cd or removable disks.. I tried to clear...
If your computer is dead set (meaning: no beep sound, the processor fan is moving but no reactions on the motherboard, no hard disk movement sounds, no display output from the video card) then the problem is your motherboard. Return it back to the seller and claim your warranty.
If your computer manage to boot up, but is displaying a " No bootable device....etc" error then the operating system in your harddisk is damage. The other possible reason is that the power supply connector or ide cable is not properly connected on your harddisk, the reason why the computer can not detect it. Or the harddisk itself is damage.
The best help you could get is to return it back and claim the warranty to replace the parts. You might somehow repair it your self, but the idea is if a computer or parts of it malfunction in just a few days used, more probably it is manufacturer defects.
Jun 15, 2010 | MSI 865GM3-LS (MS7043020) Motherboard
Acer Ferrari 4000 power up with blank screen, no
If you cannot "press DELETE to enter setup", then it's the motherboard, or the battery, or the AC power-supply that has the problem.
Since it's likely that at least one of the battery and the power-supply are working, it's probably the motherboard (or the CPU on the motherboard) that is failing.
Take the computer to a qualified technician.
Replacing the CPU is possible, and is not very expensive.
Replacing the motherboard is possible, but is very expensive
(a few hundred dollars for a replacement motherboard, plus $100 for the technician's time to disassemble/replace/reassemble).
The only "good" news is that your files on your disk-drive probably are intact, and can be read and transferred to a new computer.
Of course, you can try to sell the "dead" computer on eBay, so that somebody else can "frankenstein" your computer with their computer, to combine two dead computers into one working one.
Nov 11, 2009 | Acer Computers & Internet
No power what so ever!!
power supply could be dead in which case buy a new power supply, unless the motherboard is dead.
Mar 23, 2009 | E-Machines W3050 PC Desktop
Computer is dead will not turn on
When you buy a new motherboard, make sure and get one that accepts the same processor and memory, and video card that you have now. It is not terribly complicated to replace the motherboard but if you have never done it before be prepared to spend a few hours reinstalling your operating system and all the correct drivers for the new motherboard components. Also make sure you get a board that will fit in your computer case, not all boards are the same size.
Dec 31, 2008 | Gateway Computers & Internet
Motherboard fried for no reason and suddenly
I understand your pain. Acer has a extensive case-history of motherboards that die or quit for no reason. Do a search and you will find forums full of complaints where the machine just quit for no reason and did not start ever again.
I repair laptops for a living and see dead Acers in here all the time. Replacing the motherboard of a dead laptop is not easy. If you know how to work on computers, make sure you have a Service Manual for that make and model to make sure you can reassemble the computer. I do NOT recommend this.
I also do not recommend replacing the motherbaord at all. Firstly, only an ACER mainboard for that particular model will work - and secondly if you have to pay for another mainboard plus installation, the cost of labor and parts will likely exceed the value of the machine - which even if repaired with a new mainboard - could conk out on you all over again.
My advice - consider it totaled, invest your money in a newer model, and think twice before you buy Acer again.
Dec 19, 2008 | Acer Aspire 5100 Notebook
Motherboard dead
check for the onboard lithium battery, replace it with new on genrally the batt No. is 2030, have you checked your SMPS,
let me know.. bye... enjoy..
Dec 15, 2007 | ASUS P4P800 SE (890552603657) Motherboard
Tower will not turn on .
My first guess is to replace the power supply. These are fairly cheap and easy to replace. Unplug your computer. Just open the side of the computer (often the left facing you). The power supply is on the top which is plugged in. Remove the plug and locate 2 - 4 screws that hold it in place. Disconnect the main from the motherboard (remember where this goes for later). Install the new one and reconnect power. This is the most likely reason. If that fails, the motherboard may be dead. The green light flashing indicates that the internet is ready but has no power.
Nov 22, 2007 | HP Pavilion a815n (PS512AA) PC Desktop
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
