Question about JVC LT-40X776 40 in. LCD HDTV
Where is the hdmi port on my jvc hdmi tv - JVC LT-40X776 40 in. LCD HDTV
    New Friend:
Thanks the knight I did what you said and located the HDMI ports on my TV now I'm watching TV so I don't have to keep watching movies with no TV.
Posted on Dec 31, 2016
    Top Expert:
  • JVC Master
  • 75,289 Answers
Hello
There is a socket at the rear panel of your TV to which an HDMI to DVI cable connection. It will look like a large telephone wall socket. OK.
Posted on Mar 26, 2011
Why can't I use the HDMI port on a JVC LT-42E478?
your hdmi is not connected tight or the cable is bad,or it is dirty,use canned air to clean out plug.extend your comp screen to the tv
Jul 14, 2015 | JVC Televison & Video
I want to use my Ipad to watch movies I bought the hdmi cord and it don't work
Did you go to the input button on your remote and set the TV to HDMI port number you plugged into? They are numbered 1-4 etc depend on how many HDMI ports the TV has.
May 01, 2014 | JVC AV48P776 48" CRT TV
No optical output except when using ipod dock on tv
Unfortunately, there is a limitation on the JVC LT47P789 digital optical audio out. This audio output does not get the signal from any HDMI source. This is described on page 49 of the user manual. The manual is available from JVC here: http://resources.jvc.com/Resources/00/01/14/YA653ien.pdf . There is a similar restriction for the analog audio output from the TV with the HDMI inputs.
If you use the component audio/video inputs on the TV from your set-top cable box and DVD player, then the optical audio output will work. Otherwise, you need to find a way to connect the audio directly to the receiver. Some receivers have multiple HDMI input ports. These then forward the video signal on their HDMI output to the TV. Another option is to connect the analog audio outputs from the cable box and DVD player to the receiver. This may require resetting the Audio output from these set-top boxes to keep from sending the audio over the HDMI cable. With the Cinemate, you might need some sort of audio input switch or an HDMI converter and switch that separates the audio from the video signal.
I hope this helps. Please add a comment with more information about your devices for ideas on how to work-around the problem with this JVC TV.
Nov 05, 2017 | JVC LT42P789 42 in. LCD TV
View input from hdmi-2 JVC LT-32E478
Port 2 must be a dummy, then!
Aug 29, 2012 | JVC LT-32E478 TV
JVC LT-42X579 42 in. LCD TV
If it has more than 1 port try another---If it has component try connection there.
Mar 22, 2012 | JVC LT-42X579 42 in. LCD TV
Digital input not working and greyed out on the menu.
Most JVC TV's with HDMI and Digital Input have an optical sensor inside the case to sense if someone is trying to bypass the hardware encryption. My JVC was exposed to sunlight prolonged sunlight and triggered this optical sensor which disabled my HDMI ports. This may be the same situation for you.
JVC HDMI Port Fix
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is re-enabled.
Here's how to get to Service Menu:
Before entering the SERVICE MENU, confirm that the setting
of TV/CATV SW of the REMOTE CONTROL UNIT is at the
"TV" side and the setting of VCR/DVD SW of the REMOTE
CONTROL UNIT is at the "VCR" side. If the switches have not
been properly set, you cannot enter the SERVICE MENU.
1) Press [SLEEP TIMER] key and while the indication of
SLEEP TIMER 0 MIN is being displayed, press
[DISPLAY] key and [VIDEO STATUS] key (Fig.2)
simultaneously.
2) The SERVICE MENU screen of Fig.1 is displayed.
3) Verify what to set in the SERVICE MENU, and set
whatever is necessary (Fig.1).
Refer to the SERVICE ADJUSTMENT for setting.
4) Press the [BACK] key to return the SERVICE MENU.
Dec 12, 2010 | JVC AV-56WP74 56" Rear Projection...
Hdmi on jvc av56p575 any ideas
The first thing to do is try another HDMI source as the source you have now and the TV could possibly be incompatible. If still doesn't work with another device then try cleaning out the HDMI port on the TV because dust on the contacts can cause issues as well. If that all fails then the HDMI receiver on the main board is most likely bad. In that case it is much easier to use the component connections instead. Please take a moment to rate my answer, Thanks...
Nov 24, 2009 | JVC AV-56P575 56" Rear Projection...
No sound from JVC do have sound from TV connected
hey man my names josh i used to work in home theatre if you can clarify what your problem is i can walk you through it my cell is 832 248 4144 on thing thing yo want to check with that no sound being produced out of of hdmi is to make sure that the port that you have it running to on your tv does not have a set of analog jacks next to it. if thats the case you want get your sound cause you will have to run sound with your hdmi next to that port on the tv that is if your tv has that function and providing you have more than one hdmi port on your tv it will most be the first port you have it pluged into if not you may need to check your wiring and your pre sets on the tv as well as your wiring that your have going to every thing cause i cant promise you that everyting may be hook up like it should but i can straiten that up for ya like i said my name is josh and my cell is 832 248 4144
Nov 02, 2009 | Audio Players & Recorders
JVC LT-40X776 40 in. LCD HDTV Logo
790 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
