Question about Microsoft Xbox 360 Console
Power supply is burnt - Microsoft Xbox 360 Console
  • 643 Answers
Then you need to purchase a new power supply
Posted on Apr 23, 2011
HP Partsufer
Tech guys only.. Remove rare,side,top covers, rare metal sheet cover, you can see the Low vol power supply, check input 220V/110V(depends power standards) fuse. If fuse burnt check primary section is there any component failed? replace same rated fuse the try it.. if successful no issue, if fuse burnt repeats replace "Power Supply".
If fuse burnt after fuser drive starts, replace another fuser then try it. (faulty fuser also one of the cause to fuse burnt)
Jul 11, 2012 | HP Color Laserjet 5550dtn Printer Laserjet...
My Power supply burned cause my brother Plugged it in the New zealand power,....Im from the STATES,...What makes me concerned is that im afraid that my console is Damaged,...Please tell me its not...
Welcome to Fixya
Looks like you have a burnt power supply. Burnt power supply wont damage the console. Purchase a new power supply and problem will be solved.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Sep 29, 2011 | Microsoft Xbox 360 Console
Power supply burnt
If the power supply burnt replace the ff. componets
Pico fuse, Bridge type diode and check all shorted and open componets of primary power supply before turn it on.
Sep 20, 2010 | Samsung SyncMaster 920NW Monitor
My dell gx270 power supply has been burnt how can i repair it
If the power supply has been burnt, individual electronic components likely failed due to a power surge or other issue, and you may have experienced a short within the unit. Unfortunately, due to advanced difficulty and low cost, power supplies generally are not repaired, they are replaced instead.
Aug 04, 2010 | Dell (1N405) 180-Watt Power Supply
Burnt Power Supply
You can try replacing the fuse in the power supply if it has one. Most have a permanent circuit breaker that once tripped, the power supply is no more. If you can change the fuse, there's a 90% chance it still won't work since there was a burnt oder, which indicates the fuse didn't blow fast enough to prevent more damage, like the motherboard.
May 11, 2010 | Dell Vostro 220 Desktop Computer
Last night I heard a loud pop sound come from my computer and then it shut down. I tried to start up the computer but it didn't turn on. None of the fans turned on either so I concluded something is wrong...
Yes, and the power supply needs replacing.
4 screws hold the power supply to the cabinet or case these are usually located outside visible at the fan vents at the four corners.
Apr 19, 2010 | Ultra Products Ultra LS500 Lifetime Series...
Does it have a fuse we got hit by lighting and now the Pc wont power up
To fix the problem, you need to disassemble the power supply, replace the burnt out fuse, & also check the bridge rectifier section for burnt out rectifying diodes (these usually get burnt out if the high current gets the chance to leak past the fuse, which could sometimes happen). If you find burnt out rectifying diodes, you will need to replace them as well, as they could burn out the fuse again when you try to use the power supply while they are still there.
Dec 20, 2009 | Codegen : 350W ATX Power Supply With 12cm...
Power supply making noise and burnt smell can i adapt a normal power supply for compaqs proprietary power supply
hello,
a noise may accure in power supply due to a short circuit or fan does not run properly. if you smell like burnt then you should remove the power supply from pc and open it. then check the capaciter and other element and if you find any broken capaciter then change it with it original value.
ramesh
Nov 29, 2008 | Compaq Computers & Internet
Power supply
this is infact your video card and it can be the power supply if the burnt cable is connected to ur video card
the monitor is fine but about the burnt cable on your power supply
make sure you buy electrical tape and tape that up as soon as possible because if that burnt cable touches any part of your motherboard or anything else it will instantly fry everything which means damage everything which means ...
on the worst case scenario that has already happened
Sep 26, 2008 | Foxconn 761GXK8MB-RS Motherboard
Microsoft Xbox 360 Console Logo
18 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stu Morris K
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
