My Beko WMC62W washing machine has the pre-wash and the ready light flashing together how do I stop them flashing as it will not let me start the machine.
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 26, 2011
I have a beko wmb washing machine that stops working as soon as its put on and then the wash and ready lights start flashing... what could be wrong?
Try reading the "troubleshooting" section of the instruction manual. If you don't have the instructions, go to the Beko web site and download them.
Oct 21, 2013 | Beko Washing Machines
How to reset beko wm5120w washing machine
You need to get the dial to 90 degree program then push the start and on button together. Keep hold the start button then a light will flash. Then move the dial to spin/drain option and press start to start the reset test mode. Hope this helps.
Aug 17, 2012 | Beko Wm & Wma Models Washing Machine Motor...
The prewash light won't stop flashing and washer
get it checked by and expert it sounds like the board has gone or the door lock is faulty
Jun 28, 2009 | Washing Machines
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Beko wma 1715 pre wash led keeps flashing manual says contact service engineer
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
All we need now is for the rain to stop
May 04, 2008 | Washing Machines
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Leave power on.
Apr 26, 2008 | Washing Machines
Beko wma 1715s
The Child lock is in the on mode lol.....
Press and hold the two buttons quick wash and anti crease or
pre wash and extra rinse for 4-5 seconds ...Note the pre wash blinking light will go off and your machine will be ready to use again. the pre-wash blinking light indicates that the child lock has been activated......
Jan 05, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
347 people viewed this question
Top Washing Machines Experts
