Buzzing sound with promedia ultra 5.1 system - Audio Players & Recorders
Lost sound in left channel?
I presume you are playing a stereo cd. Plug some other device, like headphones in to see if the computer is putting out stereo. Use the same plug as the speaker system is plugged into.
I presume you have swapped the speakers to test them.
If the speakers work, and the headphones work, it's the amp.
Nov 26, 2013 | Klipsch Promedia 2.1 Thx Computer Speaker...
Crackling when i manipulate the volume control... little or no audio out of the speakers intermittently
control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver or select system devices from the device manager scroll to speaker right click to update driver,disable,scan for hardware changes or select properties to troubleshoot,then select driver to uninstall,rollback,uninstall then reinstall
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Nov 01, 2010 | Klipsch ProMedia Ultra 20 2 Speakers
Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
No longer "ultra quiet" huh?
A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
Aug 30, 2009 | Frigidaire Dishwashers
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Freezer keeps buzzing
don't worry! its the sound of compressor vibration and it is normal........if the sound is more than turn round the refrigerator and tight the nuts of the compressor stand......................have a nice day:-)
May 14, 2009 | Samsung RB2155SH Bottom Freezer...
How to hook up speakers to emachine t3638? i have the klipsch 5.1 set
The EMachines T3638 comes with High Definition Audio support and you should be able to connect a 6 speaker system (1 subwoofer and 5 speakers).
I believe they are color coded as well. I believe the speaker set you are referring to is the Klipsch ProMedia Ultra 5.1. Is that correct?
Below is the a link to the connection instruction manual. It is a pdf document that you can print out. The instructions for installing the Speaker set is on pages 3 & 4 under Signal Connection and Speak Connection.
http://www.klipsch.com/media/products/owners-manuals/ULTRA51MANUAL_ENGLISH.pdf
It should be pretty straight forward, but send me a note if you have any questions about the process.
MO
Jul 13, 2008 | Computers & Internet
Klipsch Speakers 4.1 died suddenly
Humm. Plug some earphones or another set of speakers into the computer and see if you get sound. That will at least point you in the right direction. And not to insult your intelligence but make sure the speakers are plugged into the green port.
Nov 10, 2007 | Audio Players & Recorders
Klipsh Promedia 2.1
I was face the same problem 2 year's ago.This problem occur when you move the speaker's here and there.at that time speaker's wire diconnected in inside...please check the whole wire by electricians for where exactly it is disconnected...
Sep 10, 2006 | HP ProMedia Computer Speakers
102 people viewed this question
 Grubhead
Grubhead
