Question about Danby Heating & Cooling
Air Conditioner 3 in 1 danby SPAC12030 leaking water on the floor. No water in right side compartiment also no water in the back reservoir. Water leak from right side of the machine. From the right side compatiment remove did not saw water inside base bottom of machine. Where is the water coming from????????????????
I had that problem last year. When I took it apart I found that the drainage hoses that lead to the reservoirs were plugged with dust build up. I clean out the hoses as well as the rest of the insides. I have since placed the entire unit inside a shallow (under bed) style rubermaid tote and have not had any more water leaking. Hope that helps you.
Posted on Jun 09, 2011
I dont know where the reservoir is in my air conditioner, is there a hose to hook up to drain the water becuase now it is leaking on my floor
On the Air-To Air Model, the majority of the moisture is supposed to exhausted out the exhaust hose and out the window. However, if it is extremely humid, the water collection tank will capture what is not exhausted. There is no hose, To drain it, there is a removable drain plug on the back of the unit, down near the floor level. You can either drain it in a low sided pan, that is capable of holding at least 1 quart of water. Or you can disconnect the unit and roll it to a floor drain (if you have one) or out doors to drain the water.
I hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | DeLonghi Air-To-Air Portable Air...
Danby dpac 10071 air conditioner is not cooling. a red light is on next to an icon with a full cup. Does anyone know how to make it cool?
That indicates that the water collection bucket is full and needs to be drained. Once the unit is turned OFF, unplugged and drained, the unit will start up and start cooling again. The drain hole is on the rear of the unit, just above floor level. You can either drain it in a shallow sided pan capable of holding 1 quart of water. Or roll it to a floor drain or outside to drain it.
Hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Danby DPAC10061 Air Conditioner
Water leaking from beneath unit. Some water enter buckets some leaking onto floor. Can't use the unit it leaks so much.
Look for the drain tube which sends the water to the buckets. It may be disconnected or misaligned allowing the water to go the wrong way. The tube can also be stopped up. Blow through it to clear.
Jul 22, 2011 | Danby Portable Air Conditioner
My unit is leaking tons of water only when a/c is on for a while. It leaks out of base and I have to drain tank every day. Help!!!
It is supposed to "leak" water into it's reservoir and it needs to be dumped when it gets full. That water is the humidity that the a/c is pulling form the air inside your home. As long as it's going into the reservoir and not leaking onto your floor then it is working properly.
Jun 24, 2011 | Windchaser PACR10 Portable Air Conditioner
Just got a used everstar mpk-10cr and its leaking on the bottom of the back of unit.. is there supposed to be a plug there also? it has a plug higher up on back.. I know that the water pan on the side is...
Yes there is supposed to be a screw in plug. You can probably order one directly from Danby
800-496-6049 Make sure you have the correct model numbre when you call.
Hope this helped you. Please let me know. Thanks.
Jun 19, 2011 | Danby DPAC8020 Air Conditioner
Claims that water reservoirs is full. But no water is in reservoir
If you have the additional water tank on the back installed, be sure it is connected properly....Did you hear a "click"?
also check to see if the door to the bucket is closed properly....
Nov 07, 2010 | Danby DPAC7599 Air Conditioner
My air conditioner is leaking from the front of it
Are the three drain plugs tightened?
If you're stumped, try to drain the inside tanks and see what happens: Unscrew the three drain valves at the back, and put a pan to catch any water (only a few cups). Let us know what happens.
Jul 29, 2010 | Danby DPAC120068 Air Conditioner
My danby air conditioner/dehumidifier model dpac 8399-4 leaks water all over the floor and never fills the holding tanks what can I do to fix this problem?
Probably needs cleaning. I assume it is on a level surface. Water drips from the evaporator coil into a collection tray of some type and then drains into the holding tank, this tray is either broken or the outlet is plugged.
Good Luck,
Gilsh
Nov 26, 2009 | Danby DPAC8399 Air Conditioner
Leaking water; reservoirs empty
I have this too we had that problem as well, nothing we could do about it either..
i need a new hose and exaust kit you know anywhere to get that?
this unit is ancient
May 22, 2008 | Danby DPAC7599 Air Conditioner
Danby dpac7008 portable air conditioner
I want to know how these portable air conditioners are supposed to be set up. Do they have to be on the same as the window out of which the hose goes? If the window is 4.5 feet off the ground, does the air conditioning unit need to be put on a table to make it and the window on the same level?
To the best of my knowledge the unit can stay on the floor and included the product features listed below and it does have a dehumidifier reservoir with direct drain and to make sure if you use the drain hose that the hose is higher than the item that you are draining the water into or you can elevate the unit so that the hose can drain outside and out the window - but you can also drain the water into a bucket or some thing that will hold water. I hope this will help you…..
Product Features
picexporterror From our expanded online assortment; not available in all Best Buy stores
picexporterror 7,000-BTU cooling capacity lets you cool rooms up to 250 sq. ft.
picexporterror Electronic temperature controls let you adjust the temperature in 1° increments for precision cooling; 3 fan speeds
picexporterror Dehumidifier mode removes up to 45 pints of moisture in up to 24 hours; 6.3-pint dehumidifier reservoir with direct drain
picexporterror Auto on and auto off timer
picexporterror Overload protection helps protect the air conditioner from power drains and surges
picexporterror Mesh filter is removable for quick and easy cleaning
picexporterror Includes remote
Apr 06, 2008 | Danby DPAC9030 Air Conditioner
Heating & Cooling Logo
771 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
