Question about ViewSonic N4790p 47 in. LCD TV
Have a Viewsonic LCD TV N4790p and currently unable to switch tv on. the standby light flashes blue every 30 seconds to a minute and the TV is unable to switch on. there is sound coming out but no picture.
    Scholar:
  • 150 Answers
Hello antlisa02:
First lets try a hard reset, that means unplug your tv from the outlet thats providing power to your set. Leave it unplugged for at least a couple of minutes. Plug it back in and hopefully your TV has reset itself.
Other than that you might have to have it professionally looked at.
Here is a link for your manual, maybe it might help you.
"CLICK HERE"
If this helped just click the thumbs up.
Your FixYa team member, Peter N.
Posted on Mar 26, 2011
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
Hello. I got a Lg tv which i brought 3 years ago. After putting it on standby usually the red light falshes 3 times until it turns blue and comes on. since last week the red botton just flashes...
First disconnect all power to the TV for about 30 minutes this gives the filter caps time to discharge as this resets the logic section upon power-up. After 30 min try powering back up if you still have the same problem then there's a problem with the power supply board. You may have some caps with high ESR levels which can cause this kind of fault. But it could other components on the power board causing a similar fault like switching transformers that have shorted, or opened either which can cause EDDY Currents which will cause feedback in opto-couplers and shut the TV down. Let me know what results you get after the 30 minute power-down.
Oct 18, 2010 | LG 37LG30 37 in. LCD HDTV
Panasonic TH42PZ85B troubleshooting standby light flashing red and TV will not come on line?
Have exactly the same problem. Standby light flashing twice in 1 second then off for 5 seconds but will not switch on. This after switching off on the set following around 1 hour use.
Switched all power to set off for around 30-40 minutes
Jul 02, 2010 | Panasonic Televison & Video
TV switched itself off. Standby light flashing on and off once then five rapid flashes. Tv would come on but then turn off again after a few seconds.Standby light even stayed on when tv switched off at...
Subject
Unable to Power On or Off the set
Symptoms / Customer Description
The symptom may occur while the TV is ON or in Standby.
1) If the problem occurs while the TV is in Standby:
The TV will not turn on via the remote or power button located on the set however after AC reset (i.e. unplug the TV for at least 30 seconds from the AC source) the TV returns to normal operation.
2) If the problem occurs while the TV is in use:
You may lose the ability to power off the TV or switch the video inputs however channel changing, adjusting volume, or accessing the menu may still be possible. After AC reset (i.e. unplug the TV for at least 30 seconds from the AC source) the TV returns to normal operation.
Sony has designed the BRAVIA Televisions to be CUSTOMER Software Upgradeable and therefore Sony will not pay a service claim on any issue resolved by a software upgrade. If a customer requests an update please refer them to the following website: http://www.updatemytv.com. If the unit requires the update, you may enter the customer's information in the website and a USB device will be sent to their address.
If a customer does not have access to the web please have them call the Sony Call Center Support line: 1-866-210-6333
If a customer reports either symptom above request that they unplug the set from the AC wall outlet for at least 30 seconds and then plug the set back in. This will reset the TV and it should work fine for several months. If resetting the TV does not resolve the issue the customer has a different problem and a service call by a technician may be required
Jan 02, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
BRAVIA KDL-V32A12U PICTURE LOSS
THREE Blinks
B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FIVE Blinks
AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
Jun 19, 2017 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I want to reset my TV
well when the blue light is on and ur tv is on standby, just use the channel changing button, simple!
Dec 06, 2007 | Televison & Video
I think that its some problem with your main board.so it is better to call your dealers
Nov 02, 2007 | Sony BRAVIA KDL-40S2010 40 in. LCD...
ViewSonic N4790p 47 in. LCD TV Logo
129 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
