Question about JVC RX-552V Receiver
I have everything hooked up with my surround sound, but i am getting no sound out of any of the speakers. I am getting a feed sound when i plug it into video, but other than that no sound. I have it hooked to my tv audio out and video in on the main unit. but still getting no sound.
terribleteac
SOURCE: No Prologic Surround Sound
im thinking the reciever is set to get its audio from somehwere other than the dvd, sounds like you did most of the troubleshooting but do you get audio out of the reciever if its just playing the radio or something other than a dvd?
Posted on Feb 13, 2008
  • 7 Answers
SOURCE: Philips FR965/17 Digital Audio/Video Surround Receiver
Well, if the headphones work,then the amp in the rcvr is working.
Make sure speakers are hooked up properly (Spr A, Spr B, etc.)
Be sure speakers are selected properly on the front panel.Look in the owners manual and see if its possible to reset the reciever.If this is an older unit, speaker relay may be dirty or defective or unit is in protection.If unit used to make a click after a few seconds when first turned on and now it doesn't, then the relay is not working.
Posted on Jul 21, 2008
  • 3 Answers
SOURCE: DTS Master HD audio problem
Hey! Make shure your amp and blu-ray player output and input signals are set to "bitsteam" and you are useing HDMI and optical connections. I hooked up my Onkyo tx sr 506 integrated amp to a Samsung BD 1400 player and everthing worked perfectly right out of the box. Perhaps your amp can"t decode DTS HD Master or your blue ray doesn't support it although i think a firmware upgrade may accomplish this. Put on The Chronicles of Narnia Prince Caspian which will DEFAULT to DTS HD MASTER 7.1 and see if it works. It's an excellent source to test your system. Picture and audio recieved 5 stars from Home Theatre magaziene and like i said, either your amp, or player doesn't support it or your interconnects are keeping it from coming thru. HDMI and OPTICAL connects and check your set up for "bitstream" Remember what Todd Rundgren allways said,"Everything will work if you just let it!"
Posted on Jul 26, 2009
mlapres
  • 757 Answers
SOURCE: Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Posted on Dec 23, 2009
Testimonial: "You where right on the money, I did what you said and it worked. You are the man!"
  • 128 Answers
SOURCE: how to hook up a kenwood audio-video surround
hello all you need is a good pair of RCA cables.
Use the audio output on the TV
run it to the VIDEO 1 input on the receiver
as for your DVD player vcr etc you can either run them directly to the tv as it will output whatever sound is playing to the receiver.
or
use the receiver as a video switcher and connect your components directly to it.
remember your receiver will need to be set to the input you use. ie: video 1 / dvd etc..
Hope that helps
Posted on Jan 11, 2010
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
I have no sound coming from surround speakers and sub.
Some surround modes switch speakers on or off as required. It's possible that the inputs you are using have settings that remember your previous settings, ie: no sub and surround speakers. Check the inputs and also make certain that whatever is connected to them is putting out Dolby signals.
May 04, 2017 | Pioneer VSX1020K Receiver
I can't hook up surround sound because there is outputs
there should be an audio out connection that you can feed to the input on the surround speakers. Then you will have surround sound
Mar 13, 2011 | LG 47LG60 LCD TV
When I play a DVD in the system I can only get the surround sound out of the speakers but no voices. If I play a CD or hook it up to my tv everything is ok.I have tried a number of DVD's and all have the...
sounds like you need to surround modes. There is usually a Stereo, Dolby, DTS, "virtual surround", 4-speaker mode etc..
When you play a CD or connect to TV it likely defaults to playing stereo or virtual surround.
With real surround, almost all of the voices are coming from the center-channel speaker (normally placed closest to the TV).
Also, check to make sure the center channel is connected properly.
Aug 31, 2009 | Panasonic SC-HT930 System
Unable to get sound from tv to output from surround sound
as the tv stations that were being feed into the system were digital and the nput was actually analgoue 2 optical cables are required.
have tv sound and blue ray sound through surround sound when tv channels were changed to analague.
Mar 22, 2009 | Kenwood Audio Players & Recorders
No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Feb 05, 2009 | Pioneer VSX-D608 Receiver
Hooking up logitech surround sound to tv.
you need a "y" cable to bridge the output of the tv to the speakers.
Godd Luck
Jan 21, 2009 | Logitech X-540 Computer Speakers
Pioneer VSX-815 speaker wiring
You can hook them up either way, the banana jacks are good for hooking two speakers to one terminal (ie one through the botton, one banana) but the electrical connection is the same either way. Sometimes the banana capable jacks are on speakers A and speakers B, and the surround don't accept banana plugs, your stuck with how your reciever is wired.
Dec 08, 2008 | Pioneer VSX-815-K Receiver
Kenwood KA-994 Amplifiler no sound from rear speakers.
SOUND FROM YOUR SURROUND SPEAKERS COMES BY BECAUSE OF PROCESSING THAT TAKES PLACE IN YOUR SURROUND CIRCUITS. IF THE SURROUND MODE IS ACTIVATED AND U GET NO EFFECT AND U SURE YOUR SURROND SPEAKERS ARE OPERATIONAL AND FULLY FUNCTIONAL. THEN THE PROBLEM LIES WITH YOUR SURROUND DECODING IN YOUR UNIT. REFER TO QUALIFIED SERVICING AGENTS.
Oct 08, 2007 | Audio Players & Recorders
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
